Congratulations to all the winners and a big thanks to Andy for all the great prizes!
Can same person win 2 prises if they are on different numbers?
Did I miss 5th prize drawing? So your saying there's a chance..
I was wondering the sameNot a statistician, but I'm pretty sure these aren't the correct population of numbers to choose from.
maybe I'm just dense but it's hard to sense sarcasm online. are you serious?4th prize needs to be re-done - the tickets only went 1-110. This also puts into question those numbers called from the wrong data set, which were removed from the mix for drawing the 2x IPC-Color4K-T180 special prize.
Over 300 tickets and they were all under 110, mostly double digits only... it's the wrong numbers. You can see on the wheel it stops at 110.maybe I'm just dense but it's hard to sense sarcasm online. are you serious?
trust the process. Trust Andy
Let me check with @sebastiantombs , looks like his spin not show all numbers. Will pick up again if has mistake.Over 300 tickets and they were all under 110, mostly double digits only... it's the wrong numbers. You can see on the wheel it stops at 110.
