Hi,
Just installed BI full version, v 4.6.4.6 x64, on an HP Elitedesk G2 with i7 6700 CPU, on Windows 10. I have a number of Foscam FI9900P cameras (which worked just fine with an inferior hw system in BI demo mode). I have the following settings:
- file (container) format: Blue Iris DVR
- video compression direct-to-disc
- enabled hardware acceleration
- continuous recording on local drive (not network drive)
However, the recordings result in 00sec length, which, if viewed, display a black window with error message "Unable to open file: 80000002".
If I disable hardware acceleration, everything works just fine, albeit presumably at a CPU usage penalty. I have also tried the same settings on the same hardware on Windows 8.1, with the same result.
Any suggestions as to how to make hardware acceleration work?
Thanks in advance.
Thanks in advance.
