0.17.0 with OpenVino - great improvement!!
thank you !
the video stream i setup 640x480 is still slow to start when going to view camera mode, it blacks out for like a minute intermittently. then when i select Detect button, it stays on for like a minute then it blacks out and turns off detection.
below is the log that keeps repeating in the same pattern ... frigate starts, something with detection, frigate exits, repeat
the config is below the log
log
2026-05-11 18:33:38.221109 [INFO] Preparing Frigate...
2026-05-11 18:33:38.599047 [INFO] Starting Frigate...
2026-05-11 18:33:42.217496 [2026-05-11 18:33:42] frigate.util.config INFO : Checking if frigate config needs migration...
2026-05-11 18:33:42.230291 [2026-05-11 18:33:42] frigate.util.config INFO : frigate config does not need migration...
2026-05-11 18:33:42.373336 [2026-05-11 18:33:42] frigate.util.services INFO : Automatically detected vaapi hwaccel for video decoding
2026-05-11 18:33:42.377304 [2026-05-11 18:33:42] frigate.app INFO : Starting Frigate (0.17.1-)
2026-05-11 18:33:42.394045 [2026-05-11 18:33:42] peewee_migrate.logs INFO : Starting migrations
2026-05-11 18:33:42.394581 [2026-05-11 18:33:42] peewee_migrate.logs INFO : There is nothing to migrate
2026-05-11 18:33:42.406793 [2026-05-11 18:33:42] frigate.app INFO : Recording process started: 1988052
2026-05-11 18:33:42.419759 [2026-05-11 18:33:42] frigate.app INFO : Review process started: 1988065
2026-05-11 18:33:42.421222 [2026-05-11 18:33:42] frigate.app INFO : go2rtc process pid: 34858
2026-05-11 18:33:42.653684 [2026-05-11 18:33:42] frigate.app INFO : Embedding process started: 1988075
2026-05-11 18:33:42.693473 [2026-05-11 18:33:42] frigate.app INFO : Output process started: 1988126
2026-05-11 18:33:42.723191 [2026-05-11 18:33:42] frigate.camera.maintainer INFO : Camera processor started for patio: 1988175
2026-05-11 18:33:42.760453 [2026-05-11 18:33:42] frigate.camera.maintainer INFO : Capture process started for patio: 1988232
2026-05-11 18:33:42.849526 [2026-05-11 18:33:42] frigate.api.fastapi_app INFO : Starting FastAPI app
2026-05-11 18:33:42.992613 [2026-05-11 18:33:42] frigate.api.fastapi_app INFO : FastAPI started
2026-05-11 18:33:43.089148 Process frigate.detector:detector01:
2026-05-11 18:33:43.089192 Traceback (most recent call last):
2026-05-11 18:33:43.089206 File "/usr/lib/python3.11/multiprocessing/process.py", line 314, in _bootstrap
2026-05-11 18:33:43.089218 self.run()
2026-05-11 18:33:43.089229 File "/opt/frigate/frigate/object_detection/base.py", line 143, in run
2026-05-11 18:33:43.089240 object_detector = LocalObjectDetector(detector_config=self.detector_config)
2026-05-11 18:33:43.089251 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-05-11 18:33:43.089263 File "/opt/frigate/frigate/object_detection/base.py", line 62, in init
2026-05-11 18:33:43.089274 self.detect_api = create_detector(detector_config)
2026-05-11 18:33:43.089285 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-05-11 18:33:43.089296 File "/opt/frigate/frigate/detectors/init.py", line 18, in create_detector
2026-05-11 18:33:43.089307 return api(detector_config)
2026-05-11 18:33:43.089318 ^^^^^^^^^^^^^^^^^^^^
2026-05-11 18:33:43.089329 File "/opt/frigate/frigate/detectors/plugins/openvino.py", line 45, in init
2026-05-11 18:33:43.089340 self.runner = OpenVINOModelRunner(
2026-05-11 18:33:43.089351 ^^^^^^^^^^^^^^^^^^^^
2026-05-11 18:33:43.089362 File "/opt/frigate/frigate/detectors/detection_runners.py", line 316, in init
2026-05-11 18:33:43.089373 self.compiled_model = self.ov_core.compile_model(
2026-05-11 18:33:43.089389 ^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-05-11 18:33:43.089418 File "/usr/local/lib/python3.11/dist-packages/openvino/_ov_api.py", line 610, in compile_model
2026-05-11 18:33:43.089442 super().compile_model(model, device_name, {} if config is None else config),
2026-05-11 18:33:43.089453 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-05-11 18:33:43.089463 RuntimeError: Exception from src/inference/src/cpp/core.cpp:126:
2026-05-11 18:33:43.089474 Exception from src/inference/src/dev/plugin.cpp:58:
2026-05-11 18:33:43.089490 Exception from src/plugins/auto/src/auto_schedule.cpp:428:
2026-05-11 18:33:43.089501 [AUTO] compile model failed, GPU.0:Exception from src/inference/src/dev/plugin.cpp:58:
2026-05-11 18:33:43.089511 stoi
2026-05-11 18:33:43.089522 ;
2026-05-11 18:33:45.635799 2026-05-11 18:33:43.089532
2026-05-11 18:33:45.635809 2026-05-11 18:33:43.089542
2026-05-11 18:33:45.635812 2026-05-11 18:33:43.089552
2026-05-11 18:33:47 | frigate.watchdog | Detection appears to have stopped. Exiting Frigate...
2026-05-11 18:33:57 | frigate.watchdog | Detection appears to have stopped. Exiting Frigate...
this is the config :
mqtt:
enabled: false
cameras:
patio:
enabled: true
ffmpeg:
inputs:
- path:
rtsp:/admin:[email protected]:554/cam/realmonitor?channel=1&subtype=1&unicast=true&proto=Onvif
roles:
- detect
- path:
rtsp:/admin:[email protected]:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
roles: []
detect:
width: 640
height: 480
live:
streams:
Stream 1: patio_1
Stream 2: patio_2
auth:
enabled: false
detect:
enabled: false
ffmpeg:
hwaccel_args: auto
detectors:
detector01:
type: openvino
device: AUTO
model:
width: 300
height: 300
input_tensor: nhwc
input_pixel_format: bgr
path: /openvino-model/ssdlite_mobilenet_v2.xml
labelmap_path: /openvino-model/coco_91cl_bkgr.txt
version: 0.17-0
go2rtc:
streams:
patio_1:
- rtsp:/admin:[email protected]:554/cam/realmonitor?channel=1&subtype=1&unicast=true&proto=Onvif
patio_2:
- rtsp:/admin:[email protected]:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
I tested your config and at first it didn't work on my test Frigate server, so I touched it up and fixed a few things and I have it running with detection working, give it a try and let me know if it worked. Be sure to add your RTSP password back into the stream URL in the go2rtc section.
YAML:
mqtt:
  enabled: false
ffmpeg:
  hwaccel_args: auto
go2rtc:
  streams:
    patio_1:
    patio_2:
cameras:
  patio:
    enabled: true
    ffmpeg:
      inputs:
      - path: rtsp:/127.0.0.1:8554/patio_1
        input_args: preset-rtsp-restream
        roles: []
      - path: rtsp:/127.0.0.1:8554/patio_2
        roles:
         - detect
    detect:
      width: 640
      height: 480
    live:
      streams:
        Stream 1: patio_1
        Stream 2: patio_2
auth:
  enabled: false
detectors:
  ov:
    type: openvino
    device: GPU
model:
  width: 300
  height: 300
  input_tensor: nhwc
version: 0.17-0
Reactions: slidermike
thank you !
log
mqtt:
enabled: false
cameras:
patio:
enabled: true
ffmpeg:
inputs:
- path:
roles:
- detect
- path:
roles: []
detect:
width: 640
height: 480
live:
streams:
Stream 1: patio_1
Stream 2: patio_2
auth:
enabled: false
detect:
enabled: false
ffmpeg:
hwaccel_args: auto
detectors:
detector01:
type: openvino
device: AUTO
model:
width: 300
height: 300
input_tensor: nhwc
version: 0.17-0
go2rtc:
streams:
patio_1:
patio_2:
I forgot to enable detection on by default, use this configuration instead of the last one I provided
YAML:
mqtt:
  enabled: false
ffmpeg:
  hwaccel_args: auto
auth:
  enabled: false
go2rtc:
  streams:
    patio_1:
    patio_2:
cameras:
  patio:
    enabled: true
    ffmpeg:
      inputs:
        roles: []
        roles:
         - detect
    detect:
      enabled: true
      width: 640
      height: 480
    live:
      streams:
        Stream 1: patio_1
        Stream 2: patio_2
detectors:
  ov:
    type: openvino
    device: GPU
model:
  width: 300
  height: 300
  input_tensor: nhwc
version: 0.17-0
it seems the iGPU passthru even tho its marked passthru etc, is not being used
i tried gemini AI for a couple hours yesterday, and i gave it logs and errors and config files, and it gave me back host and LXC etc commands and stuff to add, but it still is not making the passthru iGPU working in Frigate
Is it an Intel iGPU? (UHD 630, HD 530 e.g.). Assuming you are using Proxmox, there is this great guide that helped me when I was running Frigate in a LXC [TUTORIAL] - Proxmox LXC iGPU passthrough
But your best bet is to setup a Debian system (VM or Bare-metal) and installing Docker and then Frigate, though Bare-metal is a lot better since you don't need to mess with PCIe passthrough.
YAML:
mqtt:
  enabled: false
ffmpeg:
  hwaccel_args: auto
auth:
  enabled: false
go2rtc:
  streams:
    patio_1:
    patio_2:
cameras:
  patio:
    enabled: true
    ffmpeg:
      inputs:
        roles: []
        roles:
         - detect
    detect:
      enabled: true
      width: 640
      height: 480
    live:
      streams:
        Stream 1: patio_1
        Stream 2: patio_2
detectors:
  ov:
    type: openvino
    device: GPU
model:
  width: 300
  height: 300
  input_tensor: nhwc
version: 0.17-0
thank you, it didnt want to use GPU ! still GPU 0%
yeah its
i7-8700T with UHD 630
wow this did something !!! i saw GPU usage one time at 34% !!! tho now that line disappeared, the cameras still have detection enabled
Are you talking about the GPU usage in Frigate? It's very common to see a 0% with a few camera streams. Is the detection actually working in Frigate?
i figured it out / via a couple hours with g e mi ni
the hardware passthru was NOT properly working. Even tho i installed using the frigate script and it showed hardwares detected & passthru etc. Even after i did dri and other shell commands.
I had almost gave up but decided to focused ge mi ni that this is an lxc on proxmox, then it threw out some shell commands and a couple reboot/restarts later .... frigate LXC runs beautifully!!!!
This is more awesome than dwspectrum i paid for(no ai but i was passing detection from blueiris(paid)+deepstack)
i really like dwspectrum interface tho lol
