ZOSI NVR wont recognize my hard drive
shawninvan
Apr 3, 2019
15
v6h4b5
I have a zosi nvr that takes internal hard drives.
it recognized my 160g seagate hard drive but wont recognize my 500g hitachi drive. i was told it needs to be formatted in fat32 which i did..
the drive works fine on computer..
Hi tony.. i just read that thread.. can you please elaborate on the way i should format this drive????
i have now plugged the hdd in to my desktop computer..
it shows up fine and i have disk management tools to do whatever i want..
1) should i format it or not?
2) should i format in nfts or fat32?
3) partitions or no partitions?
4) initialize as gpt or mbr?
so i should delete all volume and try putting it in the nvr unformatted?????
You could do that, most DVR/NVR menus have a utility section to do so; it may just detect that it is not formatted and will ask you.
what is best chance?? put it in unformatted or nfts??
I'd try unformatted...worst that could happen is you have to pull it out and go with NTFS.
