- Sep 13, 2015
- 776
- 241
I'm newish to BI and been trying to get my head around 1 particular zone crossing and trigger that I can't work out.
I've been trying for 3 days to no avail.
I have a 5231 monitoring my front gate (gate cam)
A 59225HNI ptz on overview
Scenario:
I want to set up so that when someone enters or exits the front gate zone the ptz swings to the gate (preset 2).
Where I'm at
I configured the zones a, b and c.
I've made sure that the zones are seperate so that as you get to the gate the subject is not in both zones thus not causing a trigger.
So basically if a subject moves from zone A to B or B to A or zone A to C or C to A it fires the trigger for ptz to swing to that preset.
In object detection I've input
A-B, A-C (is this part correct)
I've also configured the HTTP command for the PTZ to fire on trigger. I've confirmed this worked correctly by testing the trigger and it does as it's supposed to.
What I can't get to work is
I can't get the zones to trigger.
So basically if I walk in the gate it doesn't trigger or if I wk out the gate It won't trigger.
I've tried adjusting the MAKE time from 0.0 to 1. I've 're adjusted the zones so that a subject can't be in any 2 zones at once (I've watched the video where this doesn't cause a trigger) so I've made sure that's not the case
Any help greatly areciated
Scenario:
Where I'm at
