So I have a Zmodo system that was partially damaged by a power surge. The NVR has a 4 port POE switch and I was running 4 of the 720p IBT15-S cameras. But it was damaged by lighting.
Well, i am trying to salvage some of the cameras for use with my new Dahua NVR. Fortunately, I was left with one good port on the Zmodo NVR, so i am able to use it somewhat in the testing process.
I have at least one camera that will function on the zmodo NVR and display a normal picture. In the zmodo NVR software, the camera has an IP of 182.168.1.11, which is the subnet of my Dahua admin portal. But not the subnet of my Dahua cameras. I believe the zmodo is running DHCP.
As a basic test of the camera, I can cover the lens of the camera and hear it switch to night mode, and switch back - when connected to the zmodo NVR.
When I plug it into my Dahua NVR, I get nothing at all. Most basically, there is no indication that the camera is powered up from the NVR because I do not hear it switch to night mode. Forthermore, it does not show up when I search for it on the Dahua. I figure that if I cannot hear it switch modes, there is very little chance of finding it on the network. I tried a manual search for the mac address of the camera too.
I have not tried to connect one of my Dahua cameras to the zmodo to verify the POE on it.
So, it seems to me that possibly the zmodo uses a proprietary POE? Any other reason? Any suggestions?
Thanks
Thanks
