Hello everyone,
I seemed to have corrupted the software on my zmodo spoe 8 channel nvr.
There is a file called hi3520d.tbz2 which is located in the /app/ location and i am in dire need of it.
If anyone has telnet access to their zmodo nvr can you please upload your copy of the hi3520d.tbz2
My NVR gets an IP and i am able to run telnet commands, however without that file i cannot load the interface as it contains some module files. Doing a firmware update does not solve this as inorder to do the update i need the GUI loaded and cant load the GUI without hi3520d.tbz2.
I would greatly appreciate it. The file should be common on 4 channel and 8 channel sPOE NVR
