Personal (2 people, each with a laptop and iPhone) - no childrenWhat networks will you require?
BI PC
possibly a guest
That's all I can think of but I may be missing something. What about smart devices like a Honeywell thermostat?
can do VLAN subnet networks on that Asus?I was wrong with the model number, it's an Asus TC-AC86U. Supports two laptops, two phones, video doorbell, smart TV and any guests that drop by with no problem. It's a dual band and has VPN built in. There is also Merlin firmware for it that will allow more features. The laptop I'm using normally connects at 1.3Gb/ps. The other one, not as powerful a WiFi dongle is at 200Mb/ps. TV streams with no problem at all. Should be in the $100 range or less.
Since OP is new, tossing in Merlin FW might be ..... advancedYeah, supposedly with the Merlin firmware you can do a couple if I remember correctly. I could easily be wrong about that though.
From the description I think two networks will work fine for this case. The IOT stuff can go on the guest network and the guest network can be blocked from access to the main network.
thestore.com
