Yellow Exclamation, no longer recording motion
IReallyLikePizza2
2,528
5,919
Houston
Yesterday I turned off my NVR as well as my PoE switch probably for the first time ever since getting my cameras installed
When it came back, two cameras are showing yellow exclamation marks and are not recording motion. The clones of the cameras are recording 24/7 as usual though, and I can view the cameras just fine
Does anyone have any ideas what might be going on here? Blue Iris gives zero information on what it thinks is wrong
Well I restarted the cameras, restarted Blue Iris and no change. If I press trigger now they will record motion, but other than that they won't detect anything
I'm going to rip my hair out. Nothing changed!
Can you share a screenshot of the trigger and motion settings?
