YCC365 plus
Andy12345
May 20, 2019
3
Melbourne
Hi. I have YCC365 plus cameras . They constantly upload to the net - is there anyway to change this so that they just record to the memory cards which are installed in them ? I understand that they should use data when I’m remote viewing but not all of the time. I’m in Melbourne and the data connection is via a 4g SIM card with a static up address. Do you think this is possible?
From the page "ycc365 plus camera rtsp url address and port number":
_________________________
RTSP stands for real-time stream protocol, it’s the primary multimedia stream protocol enables your cameras to deliver video stream. Almost network cameras rely on this protocol to transmit video/audio stream to web browser/video management software/NVR/NAS.
IP address: DHCP
username: admin
password: 123456 or no password
Port number: HTTP port (80), RTSP port (554), ONVIF port (80).
RTSP URL: rtsp://[username]:[password]@[ip]:[port]
Main stream RTSP: rtsp://admin:[email protected]:554
I would try the RTSP stream above with VLC or try the demo version of Blue Iris, have BI discover the cam.
There's another thread here, found with using the ALL forum search and key word "ycc365".
Can you log into cam's webGUI with it's LAN IP? If so, insure at some point to disable uPNP and P2P in it (if available) and also disable uPNP in router.
EDIT: once logged in, make that cam's IP static and either reserve that IP in the router OR assign a static IP to the cam that is outside of the router's DHCP server pool.
BTW, welcome to IPCT! :welcome:
Reactions: VorlonFrog
