- Sep 13, 2015
- 870
- 826
YC-HD785R-20X PTZ Camera purchased from Ali Express. The Camera claims a 150 metre (500 feet) IR range
Overcast Night on an unlit sports field
The focus target you are looking at comes from the Australia and New Zealand Police Recommendations for CCTV systems
http://www.anzpaa.org.au/our-work/pub...
In this first video the focus target is approximately 50 metres (165feet) from the Camera. The fence behind the trees is approximately 80 metres (265 feet)
Bit Rate: 8194 kbs
Shutter Speed: Auto
Gain: 100
All other settings are default
As you can see the focus hunts a little in this first video. Im not sure if that is because I am asking a lot of the camera to focus on a small target in a field of nothing. I hadn't yet unlocked the negative tilt when I took these videos so I couldn't tilt up to see if that improved things.
The focus target is approximately 25 metres (80 feet) from the Camera.
Bit Rate: 8194 kbs
Shutter Speed: Auto
Gain: 100
All other settings default.
Focus still hunting a little.
Same target distance but this time I changed the Shutter speed to a minimum of 1/100 sec so I was getting 1/4 of the light.
You can see that the fence at 80m and even the car behind it at about 90m is still visible at this setting. That would indicate to me that the 150m IR claim is pretty close to the mark.
Some people wandered into the area so I tracked them for a bit. They look a little over exposed to me as they get closer to the camera. The video drops into colour briefly so you can get an idea of how dark it was when I was testing.
So far the night time performance looks promising if i can get that focus hunt issue sorted, assuming it is actually a genuine issue and just not me asking a lot of the camera by giving it a flat plane with very little in the way of reference points. There didn't seem to be any hunting issue with tracking the moving people. The biggest issue for me at the moment with night testing is that it does not get dark enough to test until 9pm. I've been doing some calculations based on the results in the videos and 1/200s shutter should give useable video to 50m which should result in next to no motion blur.
