XM AHD7004t-LM-V3 Firmware req / flashing issue
lgdolman
Jun 18, 2020
1
england
I'm looking for replacement firmware for this unit KKMOON XF-9404NF-LM S388B-UK. Edited rc$ to enable telnet but now the dvr sits on logo at boot. Tried to reflash the firmware i have for 00000191 which does nothing as i still have shell access over uart and nothing has changed when i cat rc$. Took a photo of the original info screen which I can't access now as no GUI.
UART BOOT
Code:
Check spi flash controller v350... Found
Spi(cs1) ID: 0xC2 0x20 0x17 0xC2 0x20 0x17
Spi(cs1): Block:64KB Chip:8MB Name:"MX25L6406E"
Spi is locked. lock address[0x0 => 0x800000]
Set lock level: 2, start of bottom address
Spi is locked. lock address[0x0 => 0x20000]
envcrc 0x880c65e8
ENV_SIZE = 0xfffc
In:    serial
Out:   serial
Err:   serial
USB:   scanning bus for devices... 1 USB Device(s) found
0 Storage Device(s) found
Press CTRL-C to abort autoboot in 0 seconds8192 KiB hi_sfc at 0:0 is now current device
CFG_BOOT_ADDR:0x0
0ff:0x84000000
### /UbootLogo UbootLogoload complete: 21986 bytes loaded to 0x8e800000
jpeg decoding ...
<<addr=0x8e800000, size=0xb85f9, vobuf=0x8e800000>>
<<imgwidth=800, imgheight=600, linebytes=1600>>
decode success!!!!
decode jpeg success.
decode jpeg!
srcAddr 0x82000000, dstAddr 0x82000000
find_squashfs_file: name bin, start_block 0, offset 1378, type 1
find_squashfs_file: name boot, start_block 0, offset 1534, type 1
read inode: name boot, sb 0, of 1534, type 1
find_squashfs_file: name zImage.img, start_block 0, offset 1410, type 2
read inode: name zImage.img, sb 0, of 1410, type 2
### FS load complete: 1448352 bytes loaded to 0x82000000
## Booting kernel from Legacy Image at 82000000 ...
   Image Name:   linux
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    1448288 Bytes = 1.4 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Loading Kernel Image ... OK
OK
Starting kernel ...
Reflashing throws no errors but there is no effect as there is no changes to the file system.
Code:
mw.b 0x82000000 ff 1000000 ;tftp 0x82000000 /tftpboot/romfs-x.cramfs.img;sf probe 0;flwrite
Hisilicon ETH net controler
miiphy_register: non unique device name '0:3'
miiphy_register: non unique device name '0:2'
MAC:   00-0B-3F-00-00-01
UP_PORT : phy status change : LINK=UP : DUPLEX=FULL : SPEED=100M
TFTP from server 192.168.1.1; our IP address is 192.168.1.10
Download Filename '/tftpboot/romfs-x.cramfs.img'.
Download to address: 0x82000000
Downloading: #################################################
done
Bytes transferred = 1859648 (1c6040 hex)
## Checking Image at 0x82000000 ...
   Header CRC Checking ... OK
   Image Name:   linux
   Image Type:   ARM Linux Kernel Image (gzip compressed)
   Data Size:    1859584 Bytes = 1.8 MiB
   Load Address: 00030000
   Entry Point:  00220000
   Data CRC Checking ... OK
Programing start at: 0x00030000
Programing end at: 0x00220000
Erasing at 0x220000 -- 100% complete.
done.
Erased sectors.
Saving Image to Flash ...
Writing at 0x220000 -- 100% complete.
done.
hisilicon #
Printenv
Code:
hisilicon # printenv
bootcmd=sf probe 0;sf read 84000000 7a0000 10000;logoload 84000000;decjpg;sf read 82000000 30000 400000;squashfsload 82000000;bootm 0x82000000
bootdelay=1
baudrate=115200
bootfile="uImage"
restore=1
da=mw.b 0x82000000 ff 1000000;tftp 0x82000000 u-boot.bin.img;sf probe 0;flwrite
du=mw.b 0x82000000 ff 1000000;tftp 0x82000000 user-x.cramfs.img;sf probe 0;flwrite
dr=mw.b 0x82000000 ff 1000000;tftp 0x82000000 romfs-x.cramfs.img;sf probe 0;flwrite
dw=mw.b 0x82000000 ff 1000000;tftp 0x82000000 web-x.cramfs.img;sf probe 0;flwrite
dl=mw.b 0x82000000 ff 1000000;tftp 0x82000000 logo-x.cramfs.img;sf probe 0;flwrite
dc=mw.b 0x82000000 ff 1000000;tftp 0x82000000 custom-x.cramfs.img;sf probe 0;flwrite
up=mw.b 0x82000000 ff 1000000;tftp 0x82000000 update.img;sf probe 0;flwrite
tk=mw.b 0x82000000 ff 1000000;tftp 0x82000000 zImage.img; bootm 0x82000000
dd=mw.b 0x82000000 ff 1000000;tftp 0x82000000 mtd-x.jffs2.img;sf probe 0;flwrite
ipaddr=192.168.1.10
serverip=192.168.1.1
netmask=255.255.255.0
gatewayip=192.168.0.1
ethaddr=00:0b:3f:00:00:01
appSystemLanguage=English
appVideoStandard=PAL
bootargs=mem=132M console=ttyAMA0,115200 root=1f01 rootfstype=squashfs mtdparts=hi_sfc:192K(boot),1984K(romfs),3968K(usr),1664K(custom),64K(logo),320K(mtd)
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2010.06-svn494 (Apr 18 2017 - 14:44:23)
Environment size: 1343/65532 bytes
hisilicon #
