- Oct 14, 2017
- 1
- 0
Hi, I am thrilled to see, that I am not the only owner of a Xiongmai NBD7024, and I can see some people here with more technical expertise in this field than me.
I have a brand new NVR NBD7024-P :
杭州雄迈信息技术有限公司-8路5M/16路4M/32路1080P/32路960P 网络高清NVR主板
I bought in Beijing on a trade fair for what I thought was a bargain 100 EURO. I saw it working, and I was amazed by the quality and the price. I have not yet tried to upgrade the firmware.
THE PROBLEM :
I can't get the IPcam's connected to the NVR, I have tried a thousand times, adjusting small details, no luck. I have looked at Youtube, but the configuring is looking so simple, I can't find the problem.
I have 8 different brand new different expensive UNVIF ipcam connected directly to my Zyxel GS1910 switch. (Raysharp 4MB, Raysharp 8MB, Axis M1004-W, Axis 3364, SANYO VDC-HD3300 (old), and some less expensive but new ipcam. I can ping the IPcam's no problem.
I think I am running Xmeye software. I am only using the interface on the NVR with a mouse.
When I start the NVR, the IPcam's appear beautifully on the Digital Channel Config wizard. But I can't get them connected. I have tested if I have the correct userID and password, and that is the case.
The version is V4.02.R11.24340136.12201.130000.00000
Build date: 14-07-2016 14:27:13
Cloudserver www.dvrcenter.net
Status: 46-160715128
Nat Status: Connected
Nat status code: 2:77.75.39.202/1
The Ip address of the NVR is 192.168.0.74 (DHCP)
Subnet 255.255.255.0
Gateway 192.168.0.1 (Checked with ipconfig)
Primary DNS 192.168.0.1
Secondary DNS 0.0.0.0 or 8.8.8.8
Media port I have tried : 9988 9000 80
Http port: 80
I really need some help, maybe just a link to a user manual would be helpfull
Regards Karsten
BTW I tried also to write and call Xiongmai many times, absolutely no answer, and they also hang up on me, when I introduced me in english.
THE PROBLEM :
Http port: 80
Regards Karsten
