Mike A.
- May 6, 2017
- 4,202
- 7,073
It's very sharp as a static image at times but shows lots of noise in the image at other times. Kind of shifts back and forth. Then it loses it completely and starts showing the larger artifacts like that. Like it's struggling to maintain the color image. I've had two different V3 cams there and both did the same.
It's actually near completely dark there. The lights that you see are very dim. Porch light is only a ~7 watt equivalent LED. Basically a night light showing in the window. Pond lights are small little LEDs under the water that just make the pond glow. Cam makes them all look much much brighter. WiFi signal there is great. I have an external directional AP that I can pick up streets away pointed right at it. Inside the same shed where that's mounted and using IR, it works fine. None of the same effect. Crystal clear.
I'll put it into IR tonight to show the difference.
