Hi at all,
I've searched the forum and google for my issue and didn't find anything.
If I missed a solution, I'm sorry.
Here my System:
Modified Western Digital DX4000 with Windows Server 20008 Standard R2 and 4GB RAM:
Here my Configuration:
OS installed on SSD with latest ESU from 03.2023 (System runs only on local network, access from outside only via VPN),
Blue Iris v5 (actual version) installed on SSD,
4x8TB WD Red (NASware 3) configured as RAID 1+0,
Now... Blue Iris records my 4 cameras smoothly as it doesen't convert anything. It records the h264 stream directly to disk, so the performance is sufficient.
The Videos are stored on the RAID, not on the SSD.
I configured the storage folders correctly as usual:
The problem is, that I cannot select the ALERT-Folder in profile settings:
In version 4 of Blue Iris i could select the ALERT entry in the dropdown menu.
Now I have to configure AUX1 to the same folder as ALERT, why?
Is it a bug or did I miss something?
Alert Records have to be stored to another folder because of automated deleting after 14 days (not 10 like the standard records).
Thank you for any help if possible.
David
Here my System:
- Added a fifth SATA-Port and installed an SSD for the Operating System,
- Added an VGA-Port for connecting a VGA-Monitor,
- 4x8TB WD Red HDD (NASware 3).
David
