Specifications:
Power Supply: DC12V 1A(included)
Sensor: 1/2.9" for Sony 323 low lux CMOS
Lens: 2.7-13.5mm auto-focus, 5X optical zoom
View angle:96°~26.2°
Video resolution: 1920*1080(1080P)
IR lamp: 2pcs IR lamps + 4pcs IR white light dual-source lamps
infrared LED & white LED: Switch on APP
Night Vision Range: up to 40m
IR-CUT filter: Auto switch
Pan & Tilt: Horizontal:horizon: 0~355°, vertical: 0~90°
PTZ Preset:8 preset points
Horizontal speed:10°~30°/S
Vertical speed:8°~25°/S
Video compression:H.264
Audio compression: G.726/G.711
Onvif protocol:Support Onvif 2.4(backward compatible)
Wireless standard:IEEE 802.11 b/g/n
AP mode:Support
Ethernet: RJ-45
TF card slot: Max support 128G( TF card is not included)
Mobile Phone: Camhi for Android/iOS
Material: Plastic
Operating environment:Environment -20℃~+60℃(-4℉~+140℉)
AP mode:Support
Ethernet: RJ-45
Material: Plastic
