Worlds First Review - Dahua - IPC-Color4K-X / DH-IPC-HFW5849T1-ASE-LED - Full Color 4K Camera
Wildcat_1
2,148
6,154
US
Intro
I’m excited to be doing another Worlds First Review. this time as I mentioned in the full color thread, I’ve been testing the new Dahua full color 4K camera. This was provided courtesy of @EMPIRETECANDY for a fair, honest, no holds barred, unbiased review. I’ll attempt to answer any and all comments as always BUT please keep those to the main topic of this thread. Andy’s model for this unit is IPC-Color4K-X so remember to ask for that if you order from him. I’ve included both model numbers so people don’t get confused by the spec sheet.​
AliExpress Link For This Camera From Andy - HERE
So lets jump in and put this potential night hunter to the test.​
The Camera
So here it is, the first Dahua 4K full color. This type of cam has been wanted in the market for a long time and although there are other 4K options, many have fallen short on delivering on the promise of ‘usable’ full color at night. This cam could change all that. With 4 illuminators (2 more than it's Hik competitor) allowing for near/far adjustments + bright f1.0 1/1.2” optics and custom SOC with advanced algorithms for detecting and utilizing light this cam has a real chance of becoming a new addition to setups looking to benefit from 4K without compromising image quality within real-world use. We’ll see as I put this through some varying light tests and compare it to the current pick of most, the 5442.​
Mounting Options
The mount options for the IPC-ColorX-4K are:​
  • PFA130-E (Round Junction Box)
  • PFA122 (Square 3 hole Junction Box)
  • PFA152-E (Pole Mount)
TIP: While you can always use the PFA130E round junction box for aesthetics, I always like to offer another option which is why I list the PFA122 below (not listed on the standard spec sheet). Using a PFA 122 allows you to fast switch cams by removing the face place (with cam attached) and then placing your new/next camera mounted to another faceplate (can be PFA 122 or PFA 121 face plate) and easily attaching it to the same underlying box. Therefore if you switch your cameras out often, something that might interest you especially if you move between 3 screw hole equipped cams and 4 screw hole.​
Onto the specs
This is part of the Dahua Wizmind range so not only gets object filtering (Human, Vehicle, Non-Vehicle) as well as Face Detection, Crowd Distribution Mapping, Video Metadata and SMD (currently 2.0 but will support 3.0 when FW released). The usual IVS rules including Intrusion, Tripwire, Loitering, Parking Detection exist BUT an additional rule type (Object Monitoring) exists which allows you to track Object Placement & Object removal.​
Camera Details
Image Sensor - 1/1.2” STARVIS™ CMOS​
Effective Pixels - 3840(H) x 2160(V), 8 Megapixels​
RAM: 128MB​
ROM: 1GB​
Electronic Shutter Speed - 1/3s~1/100,000s​
Minimum Illumination
Illumination Distance - Up to 40m (131.2 ft)​
Illuination On/Off Control - Auto/Manual (Near & Far controls)​
Illumination LEDs - 4 (warm light)​
Lens Information
Focal Length (Fixed Cams)
2,8mm, 3.6mm (We’ll be discussing the 3.6mm version as thats the one I have testing)​
Max. Aperture - F1.0​
Field of View
H: 91°​
V: 50°​
D: 106°​
Close Focus Distance
5.4m (17.7 ft)​
DORI Distance
3.6mm
Detect - 120.4m (395.1ft)​
Observe - 48.2m (158.1ft)​
Recognize - 24.1m (79.1ft)​
Identify - 12.0m (39.4ft)​
Size
Here’s the engineering diagram for dimensions and remember to check out the pics in post 2​
Breakdown Of Posts
As usual I will be covering configuration, setup function, tips and tricks on how to best utilize and obviously a rundown of image quality in day/night capture scenarios. Initial vids and pics in post 2, web GUI pics in post 3, feature breakdown and testing in post 4, tips and tricks on how to make these features work and other settings / menu functions in post 5 and a summary of findings / recommendations in post 6.​
The key area to focus this review will be night performance although day will be tested too of course. For night testing my goal will be to push this camera hard from no light (only on-board illuminators) then to single bulb then to spotlight and then to how to balance a scene. I want all to clearly understand the areas the camera shines in, any limitations it has and what is needed to pull the most from it in your location.​
I’ll also put the DORI range to the test at day and night.​
This will be an interesting one, you ready ? I know I am, lets go…………………………………
Post #2 - Pics & Video's
Size comparison pics with each model listed in the image. Here I compare a 5241-Z12, 5241 (3.6mm fixed) to the Color4K-X.
Daytime Video
1 - Initial Daytime Video Test - Dahua IPC Color4K-X & Dahua 5442
As mentioned in my post below, I continue to report any issues and bugs back and have Dahua work on them. There is an issue I see currently with contrasting (dark/shadow vs light) adjustments by the camera that affects day & night. I do show how to adjust for this with WDR and the difference this causes in settings in the interim while Dahua continue to work on the fix that should be released to me later this week, early next.​
Here is the day video side by side with 5442 then with frame synced overlay. Be sure to choose 4K. Timestamps are in the description and will appear on the video timeline once YouTube finishes encoding. Enjoy !​
2 - Daytime Video Comparison - Dahua & Hikvision
This is the 2nd daytime test where I white balanced both these cameras for the FOV using pro WB cards​
Night Video
1 - Nightime Video Test - Dahua IPC Color4K-X & Dahua 5442
Tested on current FW (awaiting new bug fix release from Dahua as of 6/16/21). Details on this video in the post HERE. Be sure to use the timestamps / chapters and forcefully select 4K so you can see full res.​
2 - Nightime Video Comparison - Dahua & Hikvision
Comparing both the new Dahua IPC-Color4K-X and the Hikvision​
Post #4 - Features
Demonstrating Active Deterrence Feature
1 - Daytime Video Test
Feature Comparison Between Dahua IPC-Color4K-X / DH-IPC-HFW5894T1-ASE-LED & Hikvision DS-2CD2087G2-L(U) For Reference
FeatureDahua IPC-Color4K-X / DH-IPC-HFW5894T1-ASE-LEDHikvision DS-2CD2087G2-L(U)
Frame Rate30fps20fps
Stream Support3 Streams: Main = 4K (3840 x 2160), Sub = 704 x 480, Third = 1920 x 10803 Streams: Main = 4K (3840 x 2160), Sub = 640 x 480, Third = 1280 x 720
IRIS ControlAuto + Manual Exposure CompensationAuto No Exposure Compensation
Exposure ControlAuto, Manual, Shutter Priority. Manual & Shutter priority allow exposure ranges to be setFixed, no ranges
Illuminators4 LED’s (Individual Near & Far controls + Auto)2 LED’s (Overall brightness control + Auto)
Backlight (WDR) Sensitivity140 db130 db
Audio FeaturesBuilt In Microphone, Built In SpeakerBuilt In Microphone
AI FunctionsPerimeter Protection, Face Capture (with attributes), People Counting, Motion Detection + SMD 3.0, Heat Mapping, Object Monitoring (currently being worked by dev team on the bugs I submitted)Perimeter Protection, Face Capture, Motion Detection
Target Cropping (Ability to set a specific area to digitally zoom on within the FOV and capture.)Available (called Video Crop) on Sub Stream 2 at Full 1080p HD (1920 x 1080) at 24FpsLimited to third stream only and to 720p (1280 x 720) resolution
Camera Dimensions3.3” x 3.7” x 11.4”3.1” x 3.1” x 8.5”
Supported in cam user accounts2032
Post # 6 - Review Summary & Wrap Up
Time to wrap this review. One extra little detail before I jump in (also mentioned in Pro's below) is that this Dahua cam DOES support *Video (Target) Cropping so wanted to give that a shout out here for those wanting that functionality (its on Sub-Stream 2 and supports HD up to 24 FPS).
Wrap Up
Intro
After spending over a month with this camera and building out many videos, I wanted to provide my final thoughts along with pro’s, con’s and considerations as this camera gets ready for release next week.
As I mentioned up front, I went into this review skeptical of what this cam would offer and be capable of. Up to this point ‘color at night’ has either been a marketing slogan with little to back it up, a gimmick which has invoked a ton of noise OR limited to areas where you need equivalent light equal to daylight ! All of this and in a number of cases only on lower megapixel (MP) cameras.
4K (even during the day) while always a popular request of those new to security (and an area we generally advocate against) has only really just started to see the restrictions and performance limitations imposed on it by SOCs & optics, lifted but to date has been limited to ‘ok’ footage (unless in full daylight). You then introduce a darker (not even full night) scene and all bets are generally off. On top of these, in the past there were a ton of compromises, limited FPS, lower bitrates, noise that couldn’t be mitigated and restricted exposure settings leaving few that were any good at producing usable images with minimal blur. A large part of the restrictions on noise and quality being due to cramming in way too many megapixels into sensors too small to effectively handle them (I even wrote a post on this).
Lastly, competing manufacturers in the security market would try to mitigate any remaining gaps over each other by employing SOC & algorithmic tricks to improve appearance and perceived light penetration at the expense of image quality.
So as you can see, with a lot of previous experience coupled with a ton of unfulfilled marketing promises, I approached this review with more than a hint of skepticism as I went hands on with this new Dahua 4K and especially with color at night.
However as I started to dive in deeper, this Dahua cam started to show it could address a number of these previous concerns and push the area of 4K and color at night to a new level that makes a compelling argument for itself.
Lets Talk About This Dahua Camera (IPC-Color4K-X) Itself:
So onto this Dahua camera, have all of the concerns been mitigated ? Well, there are areas that still exist because of the way 4K color at night is implemented regardless of manufacturer (I’ll discuss the state of these next) but overall this camera is very impressive.
As I mentioned in my review, optics and SOC improvements have come a long way here but still have to be boosted through clever use of under the hood, non user accessible configuration such as AGC, Auto Iris + algorithmic adjustments. These code-base variables out of the box are mostly over-tweaked by all manufacturers right now and as I discussed, the Dahua was no exception when I first got it with its test FW. With that said Dahua has done a great job of working with me to improve this in not only what will become the shipping FW version but even more so in the 'Wildcat tweaked' version coming soon after (should be in August). What I hope I’ve shown Dahua and others is that boosting AGC and Auto Iris levels in code is NOT the right approach, it’s about balance with the ultimate goal to keep noise low and quality high. I've tried to show that by doing this in a calculated approach you can still achieve a good level of darkne penetration but in a more balanced, non 100% iris open, AGC on full approach :)
Does this mean you can see in pitch black areas, of course not BUT for those of us that utilize and deploy these products globally it’s never been just about getting an image regardless of quality but rather getting usable and identifiable captures for recognition directly or through LEO partnerships when needed. Marketing and sales like to push claims that while ‘can’ be substantiated (in perfect situations with AGC boosted to the hilt) are not useful in the real world.
Therefore I’m glad to see Dahua listen and work actively with me, take a step back and instead pursue the right path with me pointing out both image and code-base changes that could assist.
Is the camera perfect ? No (spoiler: no camera is) but it is more than a step in the right direction and definitely a camera that I would recommend. With this camera Dahua are definitely on the right path by providing good quality day and night caps with minimal noise while critically giving you access to features and configuration that are useful in the real world.
Features & functions of the camera that provide real world value, especially with color at night:
Onboard Illuminators
Take an area like onboard illuminators. While we can certainly debate whether warm (along the lines of 2700-3200k) or daylight tuned (5600k as accepted standard for high midday sunlight) would be more useful, you certainly can’t miss the fact that by having 4 LEDs with options for separate near vs far adjustment that you open up deployment opportunities especially in areas where light is at a premium. More on this in Pro's below.
Exposure Range vs Fixed Ranges
Another area is in allowing exposure ranges. While this may sound like a small thing, I can tell you from experience that being able to dial in a range is much more useful for areas with changing conditions rather than settling on 1 fixed exposure and then having to let Auto Iris and AGC adjustments take care of the rest with no control exposed to you as the user or installer. Some companies are forcing us to used fixed exposures primarily because it keeps it simple and sandboxes you into configs that they tested and are happy with. This can work for some but personally and professionally I prefer having the control so it’s nice to see this as an option on this camera.
Noise
This is a incredibly important area and I’m glad to see that Dahua has continued to make great strides in reducing and keeping video noise to a minimum. This 4K cam has much more manageable noise than in their original 4Ks. That’s not to say the 1831/2831 V1’s weren’t good (I still have a number of these deployed myself) BUT in this new cam not only has noise been reduced further but that which remains (will always be some) can be managed easily as I’ve shown many times since this is a crawl vs pulsing noise. This is a testament to the sensor being used and again represents a good pairing of SOC package to optics in the case of this IPC-Color4K-X.
Pro's, Con's & Considerations
Pros
  • Performance at night - Have to put this one at the top as night performance is key to any camera especially one being marketed on color at night. As shown in the videos you can achieve some great quality captures and overall footage with this camera whether you are using only on-board illuminators or with additional light. All of this with low amounts of noise. Just remember to dial in for your FOV and location conditions as I advocate for continually
  • Build Quality - feels well built, sturdy
  • Illuminators - 4 LEDs (near and far control) allows for fine tuning the lighting which is key to a balanced scene. Being able to dial down 'near' lighting vs 'far' can make or break captures in an FOV, even more so when you have a lot of foreground objects. Remember in the testing video's I have the power set to full on both to show whats capable in ultimate dark scenarios BUT these absolutely can be dialed back down and should be
  • Exposure range options - mentioned above but having control to implement a ranged approach allows for more flexibility to the changing FOV during day or night
  • Frame Rate Support - A number of cams top out at 15 or 20 (more than enough for most applications) BUT this cam supports 30 fps for smoother motion and more headroom to adjust regardless of your end application. Gives you more frames to work with
  • Microphone + Speaker - allows you to not only record audio from scene but also supports 2 way audio which for installations around entry and exit points is a great benefit
  • Exposure Compensation Controls - allows for a further element of control of how the camera responds to light read on scene albeit is not full manual iris control
  • ** Scheduled Smart Plan Changes - New to This Menu ** is the Ability to set smart plan event changes by schedule therefore you can have face monitoring during the day, IVS at night and people counting or heat mapping in the afternoon as an example
  • IVS Rule Options - IVS rule upgrades to include ‘appears’ within intrusion zone, ‘crosses’ line / intrusion zone (present before) and now ‘Inside’ (new option). This new addition allows your alarm and/or recording to be triggered only after x period of time a target is present in a zone
  • Additional IVS Rule Types - Object Monitoring (was working but disabled due to feedback from me on further development needed) which should return soon, People Counting, Heat Mapping
  • Audio Linkage - allows you to tie an audio file of your choice (or using on cam defaults) to a triggered alarm. LED flashes with alarm count
  • S(mart) M(otion) D(etection) 3.0 - for improved target detection and recognition at distance (Human + Vehicle) with a higher quality of target confidence over standard motion detection and SMD 2.0
  • Sub-Stream Support - rather than being limited to 640x480 etc on sub-stream, this cam supports full HD (1920 x 1080) on sub-stream 2
  • * Target Cropping * - Yes this cam does support capturing a specific portion of the image in full HD (again on Sub-Stream 2) at up to 24 FPS therefore allowing you to capture full FOV on Main Stream and a zoomed/cropped portion on Sub Stream 2 should you wish
  • Menu - I know this is a small one but important especially if you use / rely on the Web Gui (as I advocate for in configuration). The Dahua menu structure is strong, intuitive and is evolving with each release as I've noted on a number of cameras. This one is no exception with the addition of Smart Plan changes by schedule. To be fair on this point, If there is one small criticism to this, its menu consistency. While I certainly understand that certain cams (PTZ, LPR, Multi Sensor etc) need there own additional menu items, I would like to see Dahua standardize on the common elements of the menu that impact all cameras and update those in parallel.
Cons
  • D(epth) O(f) F(ield) Adjustment - This could be adjusted slightly by Dahua albeit it’s a fixed lens and will always have a sweet spot based on your chosen focal length (2.8, 3.6, 6mm). However you have to be careful what you wish for as over adjustment on these current optics lead to the very real end case of crushing either near or far object recognition. Again there will always be a sweet spot. These current optics used in these 4K at night have a very small window of adjustment leading to shallow DOF. As these cams start to have vari-focals added to their product lines you'll see optics change that allow more DOF capabilities resulting in improved focus throughout the entire focal range
  • Object monitoring - I want to see this added back and look forward to testing ASAP. This is a brilliant rule addition and has applications such as package delivery alerting for home owners as well as item monitoring in secure areas for businesses front and center. Imagine this on your porch with notifications on your next security camera delivery ;) or in business lobbies / loading docks for un-manned drop off alerting
  • No direct LED linkage controls - If Audio Linkage is set then when an event is triggered it will cause LEDs to flash to the duration of the audio repeat (i.e. 3 repetitions of audio file = 3 sets of LED flashes). Would like to see more control over when and how the LED flashes rather than just tied to audio repetitions such as flash LED's without audio etc
Considerations - Neither Pro's or Con's
  • Light Always Helps - Remember, you still need visible light (even using the illuminators) if you want to pull the best out of cams at night (unless using IR). This also acts as a visual deterrent. Don’t look at it as a challenge to push these cams as hard as you can with no light otherwise you could be disappointed and end up with an image that’s not useful. If you can pull a great image with just the illuminators, fantastic but if you have additional light don’t be afraid to use it. Also, remember that IF you rely on the onboard illuminators you may need to white balance for the FOV as auto can lean warmer in color. Daylight (adjusting for sunlight) is generally regarded as 5600k and these bulbs obviously are a lot warmer around 2700-3200k so unless manufacturers change out warm for daylight LED’s (unlikely for a while as they try to blend with 'standard', non led light (incandescent) on scene) your options are to leave auto with warm cast or white balance for night. Luckily with the Dahua you have Day vs Night profiles so you can set WB per profile once and forget
  • Still a Few Bugs Need Fixing - Update on list below although the most impactful ones have for the most part been fixed
Updated Bug List
I included this in my first few posts and wanted to post an update so you knew the latest status:
  1. SD Cards Could Not Be Read + FIXED
  2. IVS Rules Would Not Capture / Trigger Video = FIXED
  3. IVS Rules Would Not Allow Appears & Cross To Be Selected = FIXED
  4. Object Monitoring Rule
    1. Object Placement Would Only Trigger Recording On Boxes Consistently, Not Other Items - IN DEVELOPMENT EXPECTED TO BE REMOVED FOR FURTHER INVESTIGATION
    2. Object Removal Would Not Detect An Object Being Removed From The Scene = IN DEVELOPMENT EXPECTED TO BE REMOVED FOR FURTHER INVESTIGATION
  5. Camera Would Not Adjust Correctly For Contrasting Scene/FOV Where Shadow Area + Well Lit Existed In Same FOV - Affects Day & Night Scenes (ref. WDR in day video) = PARTIAL FIX that works much better now in shipping FW than my original test FW but next fixes expected in ‘Wildcat tweaked’ version IN DEVELOPMENT EXPECTED Soon
  6. Illuminators on Auto Would Only Come On When Target Was Within 2-3ft of Camera = FIXED
  7. Illuminators Turn On & Off Briefly When Set To Manual And Target Is Close To Camera = FIXED
  8. Custom Video Bitrate Does Not Survive A Reboot = IN DEVELOPMENT
  9. WebPlugin Used on Color4K-X Impacts Older 4K Plugins Causing Blank Screens in IE (for live view of older 4K cams) and Re-Download Prompts. Impacts 1831/2831/5831 models = IN DEVELOPMENT EXPECTED FIX IN NEXT FW
Summary
This cam may not be 100% perfect (as mentioned in my opener, no cam is) BUT it does represent 1 of the best options we’ve seen to date in this specific market segment and is an exciting kick off point to what comes next such as varifocal optics + larger sensors along with integration into other camera applications such as PTZ and multi sensor units.
I’m looking forward to where Dahua and other manufacturers will take this and as long as they continue to listen to feedback (as they have here and I applaud them for that) and keep FW and HW in check (as I’ve mentioned through this thread), then we all benefit from a future of solid performing products in this area.
This camera represents a solid investment now IMO and a smart stepping stone to future products. For now it offers an extremely capable and versatile diving point into 4K both day and at night (now in usable color) for personal or professional deployments and is the current best Dahua model to tackle both for this segment. Should you flood your deployment with only 4K cams (regardless of make/model) ? Absolutely not, I always advocate for choosing the best cam for each area you are installing and certainly that would include a mix of IR cams as well as special application cams (LPR, Face Recognition etc.) to meet your overall needs. However, adding this 4K cam into those deployments/setups is now something that you can / should more strongly consider even IF you want color at night due to the performance improvements seen in this camera.
Lastly, for reference, in my real world testing, the 3.6mm has its sweet spot out (from camera) to about 24 feet (approx 7.5 meters) in current shipping versions from center of lens.
This camera is definitely one I would recommend for anyone considering a 4K camera to tackle day & night and finally takes this specific resolution from 4Kan't to 4Kan ;)
Hope you've all found the review useful and I'll see you on the next one.
WC
· Built-in warm illuminator, and the max. illumination distance is 40 m with 4 LED's
Hikvision 8mp colorVu achieves 60 m with only 2 Illuminators
Reactions: tech101
I would expect the Hik to be further as it would be matched to the 4mm (Hik most sold config) optics vs 3.6 (Dahua) therefore some difference to be expected due to that. However lets also not forget that those are manufacturer stated illumination distances and lets be honest at either of them 40m (131ft) and 60m (196ft) the usefulness of the illumination provided at those distances is next to useless from a target recognition and even in some cases acquisition perspective (under current AI algoorithm limitations) especially on 3.6mm and 4mm bullet cams.
I will however be looking at getting my hands on the Hik for direct comparison there too later.
I would think between the 3.6mm & 4mm wouldn't make that much difference or very little and as you noted in bold 4 illuminators (2 more than it's Hik competitor) sounds like the Dahua will be twice as good which it won't.
I use the Hiks LED's for my yard view and are excellent compared to without them. I will look forward to a side by side comparison with the DS-2CD2T87G2-L as I do prefer the Dahua Web GUI so hoping this new Dahua is better than now the old Hik comparison.
There is not much difference BUT that is where cam manufacturers often times look to adjust illumination reach/distance is to pair with the underlying optics which is why I'm not surprised that their stated range is different. To be clear no one (speak for myself here) expects this to be twice as good and any illumination vs none (i.e. no direct light source such as bulb etc) will be an improvement but as I said, the ability for any cam with a 3.6/4mm to accurately detect (for things like SMD algorithms etc) out to 196ft (in the case of the Hik) is pushing it and certainly no one should expect evidential detail to be pulled from anywhere close to that distance relating to facial features etc at that range. As I mention the 4 LED's give more control over near vs far illumination and more control is always good :). This also ensures that IF the illuminators are your only source of light this control is important to ensure washout is kept to a minimum while maintaining range.
Yes, I'm really interested in testing against the Hik as a later test. I'm also interested in testing the final Dahua FW release based on the bugs I've found and fedback which will also impact overall image quality. Stay tuned. we'll see how manufacturer claims stack up against real world performance and usability and with direct comparison to 5442 + Hik.
I look forward to that test WC as I know you will test both to their full ability and performance and report an unbiased report back as always. I am hoping the Dahua comes out on top as I am in the market for a few more cams including a new PTZ .
Reactions: tech101
Thanks for the kind words @ljw2k. Will be doing my best and as you know I'm the biggest advocate for NOT using color at night (as up to recently this has been a gimmick in all but the best of lighting situations) therefore I intend to pull these apart for real world use :)
Thanks Wildcat, really looking forward to the test and evaluation. This new camera really has my attention.
One thing I wanted to note, the physical dimensions of the Dahua is significantly larger than the HIK. This won't matter for most but my wife about had a stroke when she saw my Dahua Full Color Bullet (4239 and mount) compared to the more trim 5442 turrets. I am all in on Dahua, I own no HIK's, I just wanted to mention the size difference for those who might be debating between the two cameras.
I’ll be putting some comparison pics against other Dahuas up tonight. Just working on editing the day video too
