- Sep 14, 2015
- 1,246
- 4,167
The way this van was being driven, you have to wonder if it was stolen. The license plate belongs to a 2005 Chevrolet Express 2500 cargo van.
I think I heard his tool box or shelf or something flip over in the van..or something loud....
Now that I think about that pop sound, you may be right about the gravel. I found a pea size piece of asphalt just below the black and white camera in front of the garage door. Since the garage door is some type of metal, that must be the pop sound that was heard during the turns.Maybe he's heard about your great video captures and he just submitted his audition tape!
Looks like his first pass at the 33 second mark threw debris, gravel or tire rubber toward your cam, right side of screen.
The camera in color is a Dahua T5442TM-AS LED with a 6mm lens. The black and white camera is a Dahua IPC-B5442E-ZE.that's a good resolution. what camera are you using there?
LPR camera is a Dahua 5231E-Z12. This is the thread I used to configure my 2 LPR cameras.Nice capture on the plates, (although van probably stolen) What camera are you using as LPR, curious about shutter speed settings too, if you don't mind, TIA!
