with latest 5.3.8.17 (and .12, I believe)... unable to auto fill in sub_stream2
May 1, 2019
2,411
3,840
Reno, NV
Somewhere back in early Jan/late Dec...I started to use the dual-stream channels for the first time (I came late the party). I hit "find/inspect"...Blue Iris auto-filled in the main stream channel. For the sub-stream, I just selected channel 1 substream1 or channel 1 substream 2 from the drop down menu selection and it would auto-fill in the box (mostly used substream 2 as that is where the D1 resolution is on all my Dahua cams). I hit ok and whalla.
Now that I am upto .17 (latest/greatest) and even when using .12, the auto-fill no longer works for substream1 or 2. Have to manually add it in to have things work.
Or did I drink too much eggnog and THOUGHT it auto-filled in the substream parameters?
If definitely auto filled as I remember doing it quite a few times when the early releases had the ONVIF bug so that external triggers stopped working.
