Wirless Camera on A "Wired NVR"?
bamani
Apr 15, 2020
2
United States
I know this might not be possible but still worth the trouble of asking.
I have a Lorex NVR N861D63B with IPO cameras.
Is there a way to get a wireless camera to work with the NVR? maybe with a converter of some kind?
thank you
thank you
Wireless cameras will always give you problems.
That said, you dont need anything special. The wireless camera will connect to your network via your router, the NVR wont know whether its wireless or wired. The camera in general has to be supported by the NVR's protocols, rtsp/onvif.
Thanks for your reply, I am surprised because when I asked Lorexs support they said that none of their wireless cameras will work with it
