Hey again!
My previous post didn't get much attention so I'm trying to rephrase my thoughts here.
I hope some of you can give your thoughts on this setup
I want to make my NVR trigger a set of 3 simple LEDs and two more powerful 48W lamps (like these) but I'm unsure how to wire things.
I'm decently capable with a soldering iron and know my way around the basics of this but I'm unsure what kinds of relays to use and how to wire them with the NVR. The NVR has alarm outputs working as Normally Open.
I've drawn a rough sketch to visualise my needs. I'm not sure the 3 LEDs in series is the smartest way but it works in my test rig.
I just need to figure out what kinds of relays (Solid state, solenoid, opto-isolator) I should use for this and if you think it would even work as intended?
Please do give any feedback you can
Cheers
Cheers
