Pass-thru, 3 prong contacts for solid or stranded, RJ-45 male crimp connectors on amazon here.
Use your image in your post #13 but with grey and purple swapped as you did before that worked.
Once working and tested, I suggest this time you protect your connection from the weather, neighbors and rodents by waterproofing it (note the use of dielectric grease again) and putting the pigtail and connection in a junction box.
