TechBill
- Nov 1, 2014
- 1,831
- 1,190
@TechBill - It might be helpful for OP if you elaborate some on your setup here. When you say you use two access points for your network, are you #1) using the same SSID for both wireless networks and #2) are they setup on different wireless channels as the OP is doing?
Different SSID or otherwise the camera will hop to the second access points if it think it have a better connection with it. I am using auto channel so both Access point will find the best channel to use .
Bill
