- Nov 4, 2014
- 12
- 0
Ok so I am planning on making a setup of IP cameras that I wish to record.
I am going to have 8 IP cameras but I am going to record them using Ethernet cables directly plugged in rather then using the internet. I am wondering how I can record these as obviously my computer does not have 8 Ethernet ports. What is the best way of recording and viewing these wired cameras?
I was thinking of plugging them all into an Ethernet switch and then having one Ethernet cable running from that to my PC; I would then use software to record them all. But will this work and enable me to use the pan/rotate functions of each of the cameras? If this idea does work will I be able to use a POE switch to power all of the cameras just using the Ethernet cables?
Thanks
Thanks
