My BI server is also my Homeseer, DVBLink and Emby pc - Yes I know I should use a separate pc for BI !!
Anyway, I have found that I have to reboot it weekly, as it slows down to a crawl. I did a full re-install of Win10 Pro, and only installed the above four programs. It worked well for a time, but then went back to needing weekly reboots.
I haven't looked in to this to figure out what is slowing it down, but thought I would ask you gentlemen if you have suffered similar problems with Win10 Pro, and what you did to sort it out.
Clearly I should answer this myself by checking what is actually slowing the pc down. Unfortunately I only thought of that as it was rebooting again
Any general advice for streamlining Win10 Pro ?
