fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,417
You have a setting wrong with respect to uac...I did this twice carefully and when I double click on the short cut it doesn't open the app? I also clicked add blue iris as a service in the settings and when I restart BI doesn't open. What could I be doing wrong? Unless it is secretly running in the background, which I don't understand how to see that it is.
Elevated Program Shortcut without UAC Prompt - Create - Windows 7 Help Forums
As far as the service it's running..it won't open bi...it runs in the background..see in task manager..to our open bi console Simply click the program icon...if running as a service you don't need or want the auto start using elevated command prompt..
