Will this PC run BI well enough to get familiar with the basics?
oldspyguy
Jan 8, 2026
18
9
Cold North
I have a Lenovo tower with the following specs.
I-5 6500 , 16G, 1050TI 4G, 500g SSD, 2TB Skyhawk.
Cameras, (1)-2MP@25fps, (2)–4MP@25fps, (1)-5MP@25fps.
Used for monitoring the road in front of my rural property. Would like to record only vehicles that pass and easily review each day.
All cameras have vehicle detection on board and one of the objectives is to learn how to utilize the AI in BI instead of / in conjunction with the cameras onboard AI. My hope is to use this platform as the first step into understanding BI before going all in.
Thank you….
People run 30+ cameras on a 4th gen just fine.
Most would recommend recording the substream 24/7 as motion can still be missed. At least that way you still have something to work with.
Most find the camera AI is better than the BI AI.
So if you have cameras with AI and all you care about is human and vehicle detection, the AI from the cameras may be all you need.
You may find that the camera AI has got so good that doing camera AI and then BI AI is kinda overkill and adds more complexity, time delay, and potential for issues.
Whether you use the camera AI or BI motion and then send to BI AI, there are scenarios in each situation that could cause the BI AI to miss it, in particular if the camera AI was slow to react, by the time BI AI gets a snapshot, the object may be out of view. People still have plenty of BI AI that shows up as nothing detected.
Whether to use camera AI or BI AI is obviously up to you, but of course, the AI in the camera may be more than sufficient for your needs without needing BI AI. Do you need the orange box around every object? Do you want to identify animals or logos? Or is just human or vehicle sufficient.
The camera AI is useful to many people, but BI has way more motion setting granularity than the cameras, and some people need that additional detail, especially if wanting AI for more than a car or person. For folks that want AI and alerts on animals or specifically a UPS truck then they need the additional AI.
There isn't really a best practice because every field of view is different and use case and needs are different.
To many here, BI motion without AI is more than adequate for what they do.
To many here, camera AI is more than adequate for what they do.
To many here, using the BI AI adds additional functionality that the above alone can not do.
It comes down to testing with each field of view and which one gives you the most consistent results.
While some of that third party stuff is cool like tagging was it a dog or a bear, I don't need all that fancy stuff. If my camera triggers BI to tag an alert for human or vehicle and BI can accomplish what I need by way of a text or email or push or whatever, that is sufficient for my needs. I just want to be alerted if a person or vehicle is on my property and the camera AI does a fine job with that.
However, I do run BI AI on a few cameras so that it knocks out headlight shine so that the alert image includes the vehicle. The camera AI will trigger for a car, but the alert image was always just the headlights. I also run the ANPR AI module.
The true test....I have found the AI of the cameras to work even in a freakin blizzard....imagine how much a camera or BI using only motion detection would be triggering! My non-AI cams in BI were triggering all night. This picture was ran through AI (without the IVS or red lines on it) and it failed to recognize a person in the picture, but the camera AI did. This pic says it all and the video had the red box over it even in complete white out on the screen:
See this thread on how using just Dahua AI may be sufficient for your needs (and other cameras with AI would perform similar):
Who uses Dahua AI capable cameras? Reliable AI for triggering events? Pro's/con's?
