Will Blue Iris for Mobile work with Android 7.1 (Nougat)?
Arjun
11,906
14,987
Milky Way
I'm looking at a ELO ESY15I1B 15.6" Touchscreen for viewing Blue Iris only. It has no battery and therefore has no chance of swelling and up and posing a risk - and it is PoE powered. Will Android 7.1 work with Blue Iris in 2026?
Also every version of UI3 ever released is available to download on github so you can extract an older copy and load it forever if that ever becomes necessary. Blue Iris is pretty good about maintaining backwards compatibility so that older apps and integrations don't get broken.
Reactions: Arjun
I never thought about the web interface on Android. Hopefully, it won't bog down the limited resources of a cheap $60 tablet. The nice thing about this tablet is that it does not rely on a internal battery whatsoever. Its all PoE powered and is wall-mountable.
Reactions: bp2008
Since that is PoE powered I assume that means it is not reliant on WiFi for networking, which is great. I expect UI3 will run perfectly with a 1080p stream and you could even edit the streaming profile to increase the quality and bit rate since it is a little low by default. Something like 4000-8000 Kbps bit rate and quality 70 (in BI 6) or quality 50 (in BI 5) should give you a pristine image (keep i-frame interval at 1000).
If UI3 doesn't run well for some reason, you can change the H.264 player between JavaScript and HTML5 to see if one player works better than the other.
You can also edit the streaming profile you're using to reduce the frame rate, resolution, bit rate, etc. Something like 5 FPS is going to use a lot less resources than 30 FPS.
You even have the option of using a jpeg streaming profile, which will work on pretty much anything. You could fish up a laptop from 2005 and if you can get it to run a reasonably modern browser, you can probably get it to run UI3 in a Jpeg profile.
And for the very oldest devices, you can always download UI2 which I expect would be able to run on an unpatched Windows XP machine using Internet Explorer.
Reactions: Arjun
