WiFi talking camera - V360 PRO
Aug 15, 2024
5
Italy
Hello everyone.
I just bought a chinese wifi video camera manageable with an android app called "V360 Pro".
The device is labeled as "IPC-FH8852v201" and "MODEL:N818".
I would like to be able to use it without the android app and also via PC. With "arp -an " I got MAC and IP address: 192.168.66.1.
When I access the camera network with my PC, and try to connect with the RTSP protocol via vlc, with the following command "rtsp:/admin:[email protected]_8554/profile0",
I get a connection error.
Could you give me some suggestions please?
Thank you so much in advance.
Regards,
Frank
If you're sure of the username, password and URL, I suggest you try leaving off the port 8554 or try 554.
-OR-
If it's ONVIF-compliant, run ODM, log in to the camera, click on "live video" in the middle, the RTSP URL should appear at bottom right of the screen.
Reactions: Praetorian.72
Thank you for your message.
No, I'm not sure about id & password, it is what I find on the web: in most case username is "admin" and password "123456". I use the IP given "by arp -an".
last result was the following:
frankk@myDebian:~$ arp -an -> (192.168.43.1) at e8:b4:c8:07:d0:69 [ether] on wlo1
So the IP seems to be dynamic, because before it was 192.168.66.1 ....
Thank you again.
