WiFi issues, drop outs.
Tazz 316
Aug 11, 2016
274
55
Yeah i know wireless sucks but i have to use it for a select few cams Hik model DS-2CD2442FWD-IW
I have 3 of them to monitor elderly parents 2 of the 3 hardly ever work the video feed comes and goes or just gives no video doing a reboot makes no difference on the router or cams.
You can log into the cams it is very slow and when you check the signal strength it shows 100%
Have you tried running a Wi-Fi Analyzer to look for possible interference from other AP's? Assuming those cams are 2.4GHz, that band is extremely polluted, especially in urban environments, and perhaps another AP on the same or adjacent channel is interfering.
EDIT 0800 CST: BTW, what is make & model of your wireless router or access point?
You're not using a "Wi-Fi extender/repeater", are you?
Use a wifi analyser.
Set up a separate access points with different log credentials , different wifi channel for the cameras. Do not use your home wifi for cameras.
What is the bit rate, frame rate, iframe, vbr cbr values. Reduce the data rate.
Think about using Ethernet over power for the cameras
I have a 2CD2442FWD and a number of annke I61DR. I have used most of them on WIFI before i moved them to a hardwired connection. The key to using wifi is a very clean clear network. No interference. I had a completely separate wifi network for my cameras. Different channels, different sidd, different access point. The max distance to the access point from the camera was 60 ft and one inside wall. Use an good analyser look at your signals and conflicts.
The 2.4 wifi signal has a lot of interference, home wireless phones, microwaves, Roku, chromecast, cell phone, smart light blubs...
Set your router to 20mhz channel width. They usually have auto, 20mhz and 40mhz options on the 2.4ghz band. Manually select 20mhz and it reduces the vulnerability to interference and increases the range you can have between router or access point and client without packet loss and the dreaded spin down of frame rate.Though you will still need to survey the area with an app like wifiman and lock your router to a channel such as 1, 6, or 11 as they don't overlap. If your neighbors are close by, their router is likely set to auto channel but by locking yours on a single channel it will prevent the scenario where your router and theirs jump to the same channels. Also seeing 100% signal does not mean the data wont be damaged by interference on the way to the router or access point. When that happens the router requests the data to be sent again, and that ends up with frame rates dropping until they recover or go to zero and stay temporarily.
20mhz is already set on 2.4 band and access point is fixed to channel 11 (low to no congestion).
This camera works great with cat5 plugged in, but over wifi with access point without 10 feet with clear line if sight is just horrendous. At work we have one of the Reolinks (i think) wifi cameras on a warehouse forklift. Works exceptionally well even far away from access point with low signal. However, it does have external antenna.
skip the wifi
try a powerline adapter that supports POE. Like
TRENDnet Powerline 200 AV PoE+ ( i have not used this device).
So shot in a dark here. Removed original antenna on one of the cameras and soldered one antenna linked above. Can't really tell the difference. Both cameras (one with new and one with original antennas) do about the same in iperf, although neither produce steady results (from 200 Kbits/s to 1.8Mbits/s)
There has to be something else wrong with wifi on this camera. Really disappointing having to resort to network cable.
Code:
# diag wifi
[ 1611.349218] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.349235] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.349252] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.349260] ipc_wifievent   S 803ca64c     0   692      1 0x00000000
[ 1611.349281] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.349298] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.349315] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.349332] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.349350] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.349366] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.349376] ipc_startwps    S 803ca64c     0   693      1 0x00000000
[ 1611.349396] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.349413] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.349433] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.349450] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.349460] ipc_wifi_scan   S 803ca64c     0   701      1 0x00000000
[ 1611.349480] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.349497] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.349514] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.349531] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.349539] netprocess_tran S 803ca64c     0   757      1 0x00000000
[ 1611.349560] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.349577] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.349597] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.349614] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.349623] davinci         S 803ca64c     0   593      1 0x00000000
[ 1611.349643] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.349660] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.349678] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.349694] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.349702] -1_service_davi S 803ca64c     0   594      1 0x00000000
[ 1611.349724] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.349738] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.349754] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.349768] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.349784] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.349792] pid593_recv_dav S 803ca64c     0   595      1 0x00000000
[ 1611.349813] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.349832] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.349849] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.349866] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.349884] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.349902] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.349910] pid593_send_dav S 803ca64c     0   596      1 0x00000000
[ 1611.349931] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.349945] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.349960] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.349975] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.349990] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.349998] ipc_watchdog    S 803ca64c     0   605      1 0x00000000
[ 1611.350018] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.350038] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.350056] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.350075] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350083] ipc_reboot      S 803ca64c     0   606      1 0x00000000
[ 1611.350104] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.350122] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.350139] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.350156] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350163] ipc_mcuthread   S 803ca64c     0   662      1 0x00000000
[ 1611.350184] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.350200] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.350218] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.350235] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350242] ipc_usrSucurty  S 803ca64c     0   663      1 0x00000000
[ 1611.350264] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.350280] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.350297] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.350314] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350322] ipc_wifilink    S 803ca64c     0   680      1 0x00000000
[ 1611.350341] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.350358] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.350376] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.350393] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350400] davinci         S 803ca64c     0   681      1 0x00000000
[ 1611.350421] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c947c>] (schedule_timeout+0x15c/0x1bc)
[ 1611.350441] [<803c947c>] (schedule_timeout+0x15c/0x1bc) from [<802dfff4>] (__skb_recv_datagram+0x2bc/0x380)
[ 1611.350459] [<802dfff4>] (__skb_recv_datagram+0x2bc/0x380) from [<802e00e8>] (skb_recv_datagram+0x30/0x38)
[ 1611.350480] [<802e00e8>] (skb_recv_datagram+0x30/0x38) from [<8036a004>] (unix_accept+0x58/0x184)
[ 1611.350499] [<8036a004>] (unix_accept+0x58/0x184) from [<802d5878>] (SyS_accept4+0xc4/0x1c0)
[ 1611.350516] [<802d5878>] (SyS_accept4+0xc4/0x1c0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350524] ipc_hdtaskctrl  S 803ca64c     0   682      1 0x00000000
[ 1611.350547] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.350573] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.350595] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.350613] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350623] ipc_dvrlogtask  S 803ca64c     0   683      1 0x00000000
[ 1611.350645] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.350662] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.350678] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.350695] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350702] ipc_Movelog     S 803ca64c     0   684      1 0x00000000
[ 1611.350723] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140)
[ 1611.350740] [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.350758] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.350776] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350783] ipc_backuptask  S 803ca64c     0   685      1 0x00000000
[ 1611.350805] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.350822] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.350838] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.350854] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350862] ipc_sdctrl      S 803ca64c     0   686      1 0x00000000
[ 1611.350882] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.350903] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.350922] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.350939] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350947] nas_config_mana S 803ca64c     0   687      1 0x00000000
[ 1611.350968] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.350988] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.351007] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.351024] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351033] ipc_record1     S 803ca64c     0   700      1 0x00000000
[ 1611.351056] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140)
[ 1611.351073] [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.351090] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.351107] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351116] ipc_wlan0_sadp  S 803ca64c     0   703      1 0x00000000
[ 1611.351139] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.351161] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.351180] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.351198] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.351215] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.351235] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351243] user_onlinetask S 803ca64c     0   706      1 0x00000000
[ 1611.351264] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.351283] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.351301] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.351318] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351325] ipc_recschdule  S 803ca64c     0   707      1 0x00000000
[ 1611.351347] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.351363] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.351380] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.351399] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351406] ipc_SdEmCrl     S 803ca64c     0   708      1 0x00000000
[ 1611.351428] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140)
[ 1611.351446] [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.351462] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.351479] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351487] ipc_soundtask   S 803ca64c     0   709      1 0x00000000
[ 1611.351509] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.351526] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.351545] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.351562] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351570] ipc_exception   S 803ca64c     0   710      1 0x00000000
[ 1611.351592] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.351610] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.351627] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.351644] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351653] auto_defense_Ct S 803ca64c     0   711      1 0x00000000
[ 1611.351675] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.351695] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.351713] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.351733] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351741] ipc_alarmInCtrl S 803ca64c     0   712      1 0x00000000
[ 1611.351762] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.351781] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.351799] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.351817] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351827] ipc_pandatask   S 803ca64c     0   713      1 0x00000000
[ 1611.351850] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.351867] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.351882] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.351899] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351906] ipc_motDetCtr   S 803ca64c     0   714      1 0x00000000
[ 1611.351930] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.351946] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.351962] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.351977] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.351993] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.352001] motdect_modectl S 803ca64c     0   715      1 0x00000000
[ 1611.352023] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.352037] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.352051] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.352065] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.352081] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.352089] ipc_smartDetCtr S 803ca64c     0   716      1 0x00000000
[ 1611.352111] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.352127] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.352143] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.352157] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.352173] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.352182] ipc_alarmin     S 803ca64c     0   717      1 0x00000000
[ 1611.352208] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.352230] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.352249] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.352268] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.352286] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.352304] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.352313] ipc_net_check   S 803ca64c     0   718      1 0x00000000
[ 1611.352337] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.352356] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.352378] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.352396] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.352405] streamRecv      R running      0   719      1 0x00000000
[ 1611.352428] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.352448] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.352466] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.352483] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.352493] stream_recv1    S 803ca64c     0   720      1 0x00000000
[ 1611.352517] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.352534] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.352552] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.352570] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.352579] ipc_alarmtohost S 803ca64c     0   721      1 0x00000000
[ 1611.352603] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140)
[ 1611.352621] [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.352638] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.352655] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.352664] ipc_SdEmsrictl  S 803ca64c     0   723      1 0x00000000
[ 1611.352688] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.352702] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.352718] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.352734] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.352750] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.352759] ipc_rtcp_timer  S 803ca64c     0   729      1 0x00000000
[ 1611.352780] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.352802] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.352822] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.352840] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.352848] ipc_dvrNetServ  S 803ca64c     0   731      1 0x00000000
[ 1611.352873] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c947c>] (schedule_timeout+0x15c/0x1bc)
[ 1611.352916] [<803c947c>] (schedule_timeout+0x15c/0x1bc) from [<8031f900>] (inet_csk_accept+0x1dc/0x230)
[ 1611.352950] [<8031f900>] (inet_csk_accept+0x1dc/0x230) from [<803467e4>] (inet_accept+0x30/0xdc)
[ 1611.352972] [<803467e4>] (inet_accept+0x30/0xdc) from [<802d5878>] (SyS_accept4+0xc4/0x1c0)
[ 1611.352993] [<802d5878>] (SyS_accept4+0xc4/0x1c0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353002] isapi_Session   S 803ca64c     0   732      1 0x00000000
[ 1611.353026] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.353045] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.353065] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.353082] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353091] ipc_timeCtrl    S 803ca64c     0   734      1 0x00000000
[ 1611.353115] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.353136] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.353155] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.353173] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353181] davinci         S 803ca64c     0   735      1 0x00000000
[ 1611.353231] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80033e68>] (sys_pause+0x34/0x54)
[ 1611.353252] [<80033e68>] (sys_pause+0x34/0x54) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353260] ipc_eth0_sadp   S 803ca64c     0   736      1 0x00000000
[ 1611.353285] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.353309] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.353328] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.353346] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.353364] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.353382] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353391] ipc_arptask     S 803ca64c     0   737      1 0x00000000
[ 1611.353415] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.353435] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.353453] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.353471] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.353489] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.353507] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353515] ipc_ContiCommd  S 803ca64c     0   738      1 0x00000000
[ 1611.353539] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.353555] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.353571] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.353588] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.353605] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353613] ipc_nei_sol     S 803ca64c     0   739      1 0x00000000
[ 1611.353636] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.353659] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.353677] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.353696] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353704] ipc_sntptask    S 803ca64c     0   740      1 0x00000000
[ 1611.353726] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.353744] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.353763] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.353781] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353789] etimer_loop     S 803ca64c     0   741      1 0x00000000
[ 1611.353812] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.353830] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.353848] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.353865] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353873] ipc_ddns        S 803ca64c     0   742      1 0x00000000
[ 1611.353897] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.353915] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.353934] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.353950] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353959] ipc_bonjour     S 803ca64c     0   743      1 0x00000000
[ 1611.353982] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.354001] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.354019] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.354036] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.354044] ipc_snmp        S 803ca64c     0   746      1 0x00000000
[ 1611.354067] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.354086] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.354105] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.354123] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.354144] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.354162] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.354170] ipc_smtp        S 803ca64c     0   748      1 0x00000000
[ 1611.354194] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.354208] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.354224] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.354239] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.354255] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.354263] ipc_evttrigcap  S 803ca64c     0   749      1 0x00000000
[ 1611.354285] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.354303] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.354322] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.354340] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.354351] ipc_timetrigcap S 803ca64c     0   750      1 0x00000000
[ 1611.354372] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.354389] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.354407] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.354425] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.354434] isp_schedule_ct S 803ca64c     0   751      1 0x00000000
[ 1611.354456] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.354473] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.354491] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.354510] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.354518] ipc_anr_task    S 803ca64c     0   752      1 0x00000000
[ 1611.354541] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.354562] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.354580] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.354599] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.354610] ipc_appweb      S 803ca64c     0   753      1 0x00000000
[ 1611.354634] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.354650] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.354669] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.354686] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.354698] events          S 803ca64c     0   754      1 0x00000000
[ 1611.354723] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.354747] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.354766] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800ba45c>] (do_sys_poll+0x308/0x3c0)
[ 1611.354785] [<800ba45c>] (do_sys_poll+0x308/0x3c0) from [<800ba5c0>] (SyS_poll+0x5c/0xd4)
[ 1611.354801] [<800ba5c0>] (SyS_poll+0x5c/0xd4) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.354809] ipc_svchandler  S 803ca64c     0   755      1 0x00000000
[ 1611.354833] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.354852] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.354870] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.354887] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.354905] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.354924] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.354934] ipc_ICRctrl_0   S 803ca64c     0   762      1 0x00000000
[ 1611.354958] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.354981] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.355001] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.355018] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355027] ipc_wdr_Ctrl_0  S 803ca64c     0   763      1 0x00000000
[ 1611.355050] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.355068] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.355087] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.355104] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355111] OnvifServCtl    S 803ca64c     0   765      1 0x00000000
[ 1611.355134] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.355152] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.355171] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.355189] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355198] ezviz_daemon    S 803ca64c     0   766      1 0x00000000
[ 1611.355218] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.355237] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.355257] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.355274] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355282] is_dis_start    S 803ca64c     0   767      1 0x00000000
[ 1611.355305] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.355323] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.355342] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.355359] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355367] ipc_flash_log   S 803ca64c     0   768      1 0x00000000
[ 1611.355393] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140)
[ 1611.355413] [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.355430] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.355447] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355456] ipc_maintain_lo S 803ca64c     0   769      1 0x00000000
[ 1611.355479] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140)
[ 1611.355498] [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.355517] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.355535] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355543] ezviz_online_ch S 803ca64c     0   772      1 0x00000000
[ 1611.355566] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.355586] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.355604] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.355626] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355634] close_base_even S 803ca64c     0   776      1 0x00000000
[ 1611.355659] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.355674] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.355690] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.355705] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.355723] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355732] ipc_OnvifEvent  S 803ca64c     0   777      1 0x00000000
[ 1611.355755] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.355775] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.355794] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.355813] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355820] ipc_OnvifExcept S 803ca64c     0   778      1 0x00000000
[ 1611.355843] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.355860] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.355879] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.355896] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355904] ipc_OnvifPTZ    S 803ca64c     0   779      1 0x00000000
[ 1611.355928] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.355946] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.355964] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.355981] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355988] onvif_probe_wla S 803ca64c     0   780      1 0x00000000
[ 1611.356012] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140)
[ 1611.356035] [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.356053] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.356072] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.356090] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.356110] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.356118] hello_server_wl S 803ca64c     0   781      1 0x00000000
[ 1611.356144] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140)
[ 1611.356161] [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.356180] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.356198] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.356205] is_multi_wifi   S 803ca64c     0   783      1 0x00000000
[ 1611.356227] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.356246] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.356264] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.356282] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.356302] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.356320] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.356329] worker.00000004 S 803ca64c     0   794      1 0x00000000
[ 1611.356353] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.356369] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.356386] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.356401] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.356417] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.356425] sdktcp54_61421  S 803ca64c     0  1029      1 0x00000000
[ 1611.356450] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c945c>] (schedule_timeout+0x13c/0x1bc)
[ 1611.356475] [<803c945c>] (schedule_timeout+0x13c/0x1bc) from [<802e11b0>] (sk_stream_wait_memory+0x1bc/0x224)
[ 1611.356514] [<802e11b0>] (sk_stream_wait_memory+0x1bc/0x224) from [<80323258>] (tcp_sendmsg+0x708/0xc84)
[ 1611.356539] [<80323258>] (tcp_sendmsg+0x708/0xc84) from [<802d4628>] (sock_aio_write+0x10c/0x138)
[ 1611.356579] [<802d4628>] (sock_aio_write+0x10c/0x138) from [<800a76f0>] (do_sync_readv_writev+0x74/0x9c)
[ 1611.356603] [<800a76f0>] (do_sync_readv_writev+0x74/0x9c) from [<800a8680>] (do_readv_writev+0xbc/0x22c)
[ 1611.356622] [<800a8680>] (do_readv_writev+0xbc/0x22c) from [<800a88b4>] (vfs_writev+0x4c/0x78)
[ 1611.356639] [<800a88b4>] (vfs_writev+0x4c/0x78) from [<800a8994>] (SyS_writev+0x3c/0x78)
[ 1611.356660] [<800a8994>] (SyS_writev+0x3c/0x78) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.356669] ipc_PrevCtrl_54 S 803ca64c     0  1030      1 0x00000000
[ 1611.356699] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.356719] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.356738] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.356758] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.356776] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.356794] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.356802] ipc_Session0    S 803ca64c     0  1065      1 0x00000000
[ 1611.356826] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.356845] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.356863] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.356881] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.356899] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.356917] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.356925] rtsptcp43_61636 S 803ca64c     0  1066      1 0x00000000
[ 1611.356950] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c945c>] (schedule_timeout+0x13c/0x1bc)
[ 1611.356969] [<803c945c>] (schedule_timeout+0x13c/0x1bc) from [<802e11b0>] (sk_stream_wait_memory+0x1bc/0x224)
[ 1611.356994] [<802e11b0>] (sk_stream_wait_memory+0x1bc/0x224) from [<80323258>] (tcp_sendmsg+0x708/0xc84)
[ 1611.357017] [<80323258>] (tcp_sendmsg+0x708/0xc84) from [<802d4628>] (sock_aio_write+0x10c/0x138)
[ 1611.357035] [<802d4628>] (sock_aio_write+0x10c/0x138) from [<800a76f0>] (do_sync_readv_writev+0x74/0x9c)
[ 1611.357053] [<800a76f0>] (do_sync_readv_writev+0x74/0x9c) from [<800a8680>] (do_readv_writev+0xbc/0x22c)
[ 1611.357069] [<800a8680>] (do_readv_writev+0xbc/0x22c) from [<800a88b4>] (vfs_writev+0x4c/0x78)
[ 1611.357086] [<800a88b4>] (vfs_writev+0x4c/0x78) from [<800a8994>] (SyS_writev+0x3c/0x78)
[ 1611.357106] [<800a8994>] (SyS_writev+0x3c/0x78) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.357115] worker.00000006 S 803ca64c     0  1146      1 0x00000000
[ 1611.357139] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.357154] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.357171] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.357187] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.357205] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.357214] kworker/u2:2    S 803ca64c     0   597      2 0x00000000
[ 1611.357271] [<803ca64c>] (__schedule+0x1bc/0x428) from [<8003b2dc>] (worker_thread+0x22c/0x458)
[ 1611.357293] [<8003b2dc>] (worker_thread+0x22c/0x458) from [<80040d98>] (kthread+0xb4/0xb8)
[ 1611.357310] [<80040d98>] (kthread+0xb4/0xb8) from [<8000ead8>] (ret_from_fork+0x14/0x3c)
[ 1611.357319] hikdsp          S 803ca64c     0   633      1 0x00000000
[ 1611.357341] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.357363] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.357384] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.357402] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.357410] hikdsp          S 803ca64c     0   641      1 0x00000000
[ 1611.357433] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c947c>] (schedule_timeout+0x15c/0x1bc)
[ 1611.357457] [<803c947c>] (schedule_timeout+0x15c/0x1bc) from [<802dfff4>] (__skb_recv_datagram+0x2bc/0x380)
[ 1611.357475] [<802dfff4>] (__skb_recv_datagram+0x2bc/0x380) from [<802e00e8>] (skb_recv_datagram+0x30/0x38)
[ 1611.357514] [<802e00e8>] (skb_recv_datagram+0x30/0x38) from [<802ff9ec>] (netlink_recvmsg+0x3c/0x2d0)
[ 1611.357540] [<802ff9ec>] (netlink_recvmsg+0x3c/0x2d0) from [<802d3b40>] (sock_recvmsg+0x84/0xa8)
[ 1611.357563] [<802d3b40>] (sock_recvmsg+0x84/0xa8) from [<802d4bec>] (___sys_recvmsg.part.31+0xd8/0x190)
[ 1611.357587] [<802d4bec>] (___sys_recvmsg.part.31+0xd8/0x190) from [<802d6178>] (__sys_recvmsg+0x50/0x80)
[ 1611.357605] [<802d6178>] (__sys_recvmsg+0x50/0x80) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.357613] ipc_host_cmd    S 803ca64c     0   644      1 0x00000000
[ 1611.357667] [<803ca64c>] (__schedule+0x1bc/0x428) from [<8019b424>] (SyS_semtimedop+0x7bc/0xc40)
[ 1611.357691] [<8019b424>] (SyS_semtimedop+0x7bc/0xc40) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.357700] ipc_bs_reader   S 803ca64c     0   645      1 0x00000000
[ 1611.357864] [<803ca64c>] (__schedule+0x1bc/0x428) from [<7f069fb4>] (iav_query_framedesc+0x19c/0x3d4 [iav])
[ 1611.357964] [<7f069fb4>] (iav_query_framedesc+0x19c/0x3d4 [iav]) from [<7f06a35c>] (iav_ioc_g_query_desc+0xec/0x428 [iav])
[ 1611.358043] [<7f06a35c>] (iav_ioc_g_query_desc+0xec/0x428 [iav]) from [<7f05f748>] (iav_encode_ioctl+0x620/0x1868 [iav])
[ 1611.358102] [<7f05f748>] (iav_encode_ioctl+0x620/0x1868 [iav]) from [<7f052cfc>] (iav_ioctl+0x12c/0x2ac [iav])
[ 1611.358149] [<7f052cfc>] (iav_ioctl+0x12c/0x2ac [iav]) from [<800b8860>] (do_vfs_ioctl+0x418/0x5e8)
[ 1611.358172] [<800b8860>] (do_vfs_ioctl+0x418/0x5e8) from [<800b8a68>] (SyS_ioctl+0x38/0x60)
[ 1611.358195] [<800b8a68>] (SyS_ioctl+0x38/0x60) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.358205] dsp_audio_input S 803ca64c     0   646      1 0x00000000
[ 1611.358236] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140)
[ 1611.358256] [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.358276] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800ba45c>] (do_sys_poll+0x308/0x3c0)
[ 1611.358294] [<800ba45c>] (do_sys_poll+0x308/0x3c0) from [<800ba5c0>] (SyS_poll+0x5c/0xd4)
[ 1611.358311] [<800ba5c0>] (SyS_poll+0x5c/0xd4) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.358319] dsp_audio_encod S 803ca64c     0   647      1 0x00000000
[ 1611.358342] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.358368] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.358387] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.358405] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.358412] ipc_Voicetalk   S 803ca64c     0   648      1 0x00000000
[ 1611.358433] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.358452] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.358470] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.358489] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.358497] hikdsp          S 803ca64c     0   649      1 0x00000000
[ 1611.358519] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.358536] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.358554] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.358573] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.358582] ipc_audio_iad   R running      0   650      1 0x00000000
[ 1611.358606] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.358624] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.358643] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.358660] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.358667] yuv_data_read   S 803ca64c     0   651      1 0x00000000
[ 1611.358691] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.358706] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.358723] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.358738] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.358757] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.358765] ipc_mtd         S 803ca64c     0   652      1 0x00000000
[ 1611.358788] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.358805] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.358824] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.358841] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.358851] ipc_smd_process S 803ca64c     0   653      1 0x00000000
[ 1611.358872] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.358889] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.358908] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.358926] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.358934] ipc_fd_main     S 803ca64c     0   654      1 0x00000000
[ 1611.358958] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.358978] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.358997] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.359014] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.359027] ipc_fd_upload   S 803ca64c     0   655      1 0x00000000
[ 1611.359052] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.359068] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.359086] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.359102] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.359120] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.359130] text_osd_thread R running      0   656      1 0x00000000
[ 1611.359150] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.359170] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.359190] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.359207] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.359217] ipc_zoom        S 803ca64c     0   657      1 0x00000000
[ 1611.359240] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.359258] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.359278] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.359294] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.359302] ipc_vsnc_guard  S 803ca64c     0   658      1 0x00000000
[ 1611.359325] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c947c>] (schedule_timeout+0x15c/0x1bc)
[ 1611.359351] [<803c947c>] (schedule_timeout+0x15c/0x1bc) from [<802dfff4>] (__skb_recv_datagram+0x2bc/0x380)
[ 1611.359370] [<802dfff4>] (__skb_recv_datagram+0x2bc/0x380) from [<802e00e8>] (skb_recv_datagram+0x30/0x38)
[ 1611.359396] [<802e00e8>] (skb_recv_datagram+0x30/0x38) from [<802ff9ec>] (netlink_recvmsg+0x3c/0x2d0)
[ 1611.359421] [<802ff9ec>] (netlink_recvmsg+0x3c/0x2d0) from [<802d3b40>] (sock_recvmsg+0x84/0xa8)
[ 1611.359441] [<802d3b40>] (sock_recvmsg+0x84/0xa8) from [<802d4bec>] (___sys_recvmsg.part.31+0xd8/0x190)
[ 1611.359464] [<802d4bec>] (___sys_recvmsg.part.31+0xd8/0x190) from [<802d6178>] (__sys_recvmsg+0x50/0x80)
[ 1611.359481] [<802d6178>] (__sys_recvmsg+0x50/0x80) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.359489] ipc_smart264    S 803ca64c     0   659      1 0x00000000
[ 1611.359510] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c945c>] (schedule_timeout+0x13c/0x1bc)
[ 1611.359532] [<803c945c>] (schedule_timeout+0x13c/0x1bc) from [<8001beb0>] (ambsync_proc_read+0xe8/0x1b0)
[ 1611.359560] [<8001beb0>] (ambsync_proc_read+0xe8/0x1b0) from [<800f6674>] (proc_reg_read+0x50/0x78)
[ 1611.359590] [<800f6674>] (proc_reg_read+0x50/0x78) from [<800a7c6c>] (vfs_read+0x98/0x144)
[ 1611.359612] [<800a7c6c>] (vfs_read+0x98/0x144) from [<800a82cc>] (SyS_read+0x3c/0x78)
[ 1611.359629] [<800a82cc>] (SyS_read+0x3c/0x78) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.359638] ipc_smart264_se S 803ca64c     0   660      1 0x00000000
[ 1611.359661] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.359681] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.359699] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.359716] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.359725] ipc_vin_trigger S 803ca64c     0   661      1 0x00000000
[ 1611.359748] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c945c>] (schedule_timeout+0x13c/0x1bc)
[ 1611.359763] [<803c945c>] (schedule_timeout+0x13c/0x1bc) from [<8001beb0>] (ambsync_proc_read+0xe8/0x1b0)
[ 1611.359781] [<8001beb0>] (ambsync_proc_read+0xe8/0x1b0) from [<800f6674>] (proc_reg_read+0x50/0x78)
[ 1611.359799] [<800f6674>] (proc_reg_read+0x50/0x78) from [<800a7c6c>] (vfs_read+0x98/0x144)
[ 1611.359815] [<800a7c6c>] (vfs_read+0x98/0x144) from [<800a82cc>] (SyS_read+0x3c/0x78)
[ 1611.359831] [<800a82cc>] (SyS_read+0x3c/0x78) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.359840] hikdsp          S 803ca64c     0   704      1 0x00000000
[ 1611.359887] [<803ca64c>] (__schedule+0x1bc/0x428) from [<7f0310e4>] (img_get_statistics+0xe4/0x7cc [imgproc])
[ 1611.359922] [<7f0310e4>] (img_get_statistics+0xe4/0x7cc [imgproc]) from [<7f032a88>] (amba_imgproc_cmd+0x708/0x239c [imgproc])
[ 1611.359990] [<7f032a88>] (amba_imgproc_cmd+0x708/0x239c [imgproc]) from [<7f052de0>] (iav_ioctl+0x210/0x2ac [iav])
[ 1611.360045] [<7f052de0>] (iav_ioctl+0x210/0x2ac [iav]) from [<800b8860>] (do_vfs_ioctl+0x418/0x5e8)
[ 1611.360066] [<800b8860>] (do_vfs_ioctl+0x418/0x5e8) from [<800b8a68>] (SyS_ioctl+0x38/0x60)
[ 1611.360087] [<800b8a68>] (SyS_ioctl+0x38/0x60) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.360097] psh             S 803ca64c     0   639      1 0x00000000
[ 1611.360123] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c947c>] (schedule_timeout+0x15c/0x1bc)
[ 1611.360144] [<803c947c>] (schedule_timeout+0x15c/0x1bc) from [<80041534>] (wait_woken+0x30/0x50)
[ 1611.360173] [<80041534>] (wait_woken+0x30/0x50) from [<80208d50>] (n_tty_read+0x1fc/0x854)
[ 1611.360195] [<80208d50>] (n_tty_read+0x1fc/0x854) from [<80203bac>] (tty_read+0x7c/0xcc)
[ 1611.360214] [<80203bac>] (tty_read+0x7c/0xcc) from [<800a7c6c>] (vfs_read+0x98/0x144)
[ 1611.360230] [<800a7c6c>] (vfs_read+0x98/0x144) from [<800a82cc>] (SyS_read+0x3c/0x78)
[ 1611.360248] [<800a82cc>] (SyS_read+0x3c/0x78) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.360258] init            S 803ca64c     0   640      1 0x00000000
[ 1611.360282] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c947c>] (schedule_timeout+0x15c/0x1bc)
[ 1611.360301] [<803c947c>] (schedule_timeout+0x15c/0x1bc) from [<80041534>] (wait_woken+0x30/0x50)
[ 1611.360316] [<80041534>] (wait_woken+0x30/0x50) from [<80208d50>] (n_tty_read+0x1fc/0x854)
[ 1611.360331] [<80208d50>] (n_tty_read+0x1fc/0x854) from [<80203bac>] (tty_read+0x7c/0xcc)
[ 1611.360350] [<80203bac>] (tty_read+0x7c/0xcc) from [<800a7c6c>] (vfs_read+0x98/0x144)
[ 1611.360365] [<800a7c6c>] (vfs_read+0x98/0x144) from [<800a82cc>] (SyS_read+0x3c/0x78)
[ 1611.360383] [<800a82cc>] (SyS_read+0x3c/0x78) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.360391] RTW_CMD_THREAD  S 803ca64c     0   688      2 0x00000000
[ 1611.360414] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c947c>] (schedule_timeout+0x15c/0x1bc)
[ 1611.360431] [<803c947c>] (schedule_timeout+0x15c/0x1bc) from [<803ca244>] (__down_interruptible+0xb0/0xf4)
[ 1611.360449] [<803ca244>] (__down_interruptible+0xb0/0xf4) from [<80045d14>] (down_interruptible+0x7c/0x90)
[ 1611.361028] [<80045d14>] (down_interruptible+0x7c/0x90) from [<7f19963c>] (_rtw_down_sema+0x8/0x14 [8188eu])
[ 1611.361422] [<7f19963c>] (_rtw_down_sema+0x8/0x14 [8188eu]) from [<7f15da24>] (rtw_cmd_thread+0x84/0x428 [8188eu])
[ 1611.361556] [<7f15da24>] (rtw_cmd_thread+0x84/0x428 [8188eu]) from [<80040d98>] (kthread+0xb4/0xb8)
[ 1611.361588] [<80040d98>] (kthread+0xb4/0xb8) from [<8000ead8>] (ret_from_fork+0x14/0x3c)
[ 1611.361599] dropbear        S 803ca64c     0  1086      1 0x00000000
[ 1611.361633] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140)
[ 1611.361666] [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.361685] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.361703] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.361720] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.361741] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.361749] dropbear        S 803ca64c     0  1094   1086 0x00000000
[ 1611.361772] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.361791] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.361809] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.361829] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.361846] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.361863] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.361872] psh             S 803ca64c     0  1097   1094 0x00000000
[ 1611.361908] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80027328>] (do_wait+0x210/0x230)
[ 1611.361930] [<80027328>] (do_wait+0x210/0x230) from [<80027770>] (SyS_wait4+0x5c/0xc0)
[ 1611.361947] [<80027770>] (SyS_wait4+0x5c/0xc0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.361955] kworker/0:2     R running      0  1222      2 0x00000000
[ 1611.362005] [<803ca64c>] (__schedule+0x1bc/0x428) from [<8003b2dc>] (worker_thread+0x22c/0x458)
[ 1611.362026] [<8003b2dc>] (worker_thread+0x22c/0x458) from [<80040d98>] (kthread+0xb4/0xb8)
[ 1611.362043] [<80040d98>] (kthread+0xb4/0xb8) from [<8000ead8>] (ret_from_fork+0x14/0x3c)
[ 1611.362050] sh              x 803ca64c     0  1231    681 0x00000004
[ 1611.362074] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80026318>] (do_exit+0x65c/0x914)
[ 1611.362092] [<80026318>] (do_exit+0x65c/0x914) from [<800274bc>] (do_group_exit+0x40/0xdc)
[ 1611.362111] [<800274bc>] (do_group_exit+0x40/0xdc) from [<80027568>] (__wake_up_parent+0x0/0x18)
[ 1611.362120] sh              x 803ca64c     0  1233    681 0x00000004
[ 1611.362142] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80026318>] (do_exit+0x65c/0x914)
[ 1611.362159] [<80026318>] (do_exit+0x65c/0x914) from [<800274bc>] (do_group_exit+0x40/0xdc)
[ 1611.362176] [<800274bc>] (do_group_exit+0x40/0xdc) from [<80027568>] (__wake_up_parent+0x0/0x18)
[ 1611.362184] diag            R running      0  1247   1097 0x00000000
[ 1611.362218] [<80013108>] (unwind_backtrace+0x0/0x134) from [<8001176c>] (show_stack+0x10/0x14)
[ 1611.362258] [<8001176c>] (show_stack+0x10/0x14) from [<8004b5c8>] (show_state_filter+0x64/0x8c)
[ 1611.362295] [<8004b5c8>] (show_state_filter+0x64/0x8c) from [<8020eed4>] (__handle_sysrq+0xc0/0x1ac)
[ 1611.362316] [<8020eed4>] (__handle_sysrq+0xc0/0x1ac) from [<8020f3c4>] (write_sysrq_trigger+0x38/0x48)
[ 1611.362339] [<8020f3c4>] (write_sysrq_trigger+0x38/0x48) from [<800f65fc>] (proc_reg_write+0x50/0x78)
[ 1611.362364] [<800f65fc>] (proc_reg_write+0x50/0x78) from [<800a7dcc>] (vfs_write+0xb4/0x194)
[ 1611.362382] [<800a7dcc>] (vfs_write+0xb4/0x194) from [<800a8344>] (SyS_write+0x3c/0x78)
[ 1611.362400] [<800a8344>] (SyS_write+0x3c/0x78) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
################################ Base log collection ################################
=====prtHardInfo=====
Start at 2019-03-25 20:26:51
Serial NO :DS-2CD2442FWD-IW20181105AAWRC63216252
V5.5.53 build 180730
NetProcess Version: 5.10.2 [10:10:37-Feb 11 2018]
Path: /Camera/Platform/Branches/branches_FSP_network_protocol/FSP_network_protocol_for_5.5.0_r3_r7
Last Changed Rev: 353818
Last Changed Date: 2018-01-06 14:56:36 +0800 (Sat, 06 Jan 2018)
Db Encrypt Version: 131072
Db Major Version: 1184
Db svn info:
Path: /Camera/Platform/Branches/branches_frontend_software_platform/IPC_develop_branch/ipc_baseline/baseline_R6
Last Changed Rev: 417896
Last Changed Date: 2018-07-30 11:14:21 +0800 (Mon, 30 Jul 2018)
hardwareVersion = 0x0
hardWareExtVersion      = 0x0
encodeChans             = 1
decodeChans             = 1
alarmInNums             = 1
alarmOutNums            = 1
ataCtrlNums             = 0
flashChipNums           = 0
rms                             = 0x4000000
networksNums            = 1
language                        = 1
devType                 = 0x22250
net reboot count        = 0
vi_type                 = 32
firmwareCode            = 0000000200000100000000010781bc6f000000010000000100000002ffffffff050500350012071e00022250
=========uptime======
1781.65 1508.24
=========date========
Mon Mar 25 20:55:56 UTC 2019
=======version=======
trunk.381643
==========ps=========
  PID USER       VSZ STAT COMMAND
    1 admin     2244 S    init
    2 admin        0 SW   [kthreadd]
    3 admin        0 SW   [ksoftirqd/0]
    4 admin        0 SW   [kworker/0:0]
    5 admin        0 SW<  [kworker/0:0H]
    6 admin        0 SW   [kworker/u2:0]
    7 admin        0 SW<  [khelper]
    8 admin        0 SW   [kdevtmpfs]
    9 admin        0 SW<  [writeback]
   10 admin        0 SW<  [bioset]
   11 admin        0 SW<  [crypto]
   12 admin        0 SW<  [kblockd]
   22 admin        0 SW   [kworker/0:1]
   23 admin        0 SW<  [rpciod]
   24 admin        0 SW   [kswapd0]
   25 admin        0 SWN  [ksmd]
   26 admin        0 SW   [fsnotify_mark]
   27 admin        0 SW<  [nfsiod]
   28 admin        0 SW<  [cifsiod]
   42 admin        0 SW   [spi0]
   45 admin        0 SW<  [deferwq]
   55 admin     1392 S <  /sbin/udevd -d
  271 admin        0 SW   [ubi_bgt1d]
  278 admin        0 SW   [ubifs_bgt1_0]
  282 admin        0 SW   [ubi_bgt3d]
  289 admin        0 SW   [ubifs_bgt3_0]
  294 admin        0 SW   [ubi_bgt4d]
  299 admin        0 SW   [ubifs_bgt4_0]
  325 admin     1200 S    /bin/network_deamon -d 0x0f -r 0x01 -t 60
  371 admin        0 SW   [iav_guard]
  400 admin        0 DW   [mark_mergeable]
  417 admin        0 SW   [khubd]
  570 admin     4052 S    /bin/execSystemCmd
  572 admin     5972 S    /home/process/daemon_fsp_app
  578 admin    20248 S    /home/process/database_process
  579 admin    27516 S    /home/process/net_process
  593 admin     231m S <  /home/davinci
  597 admin        0 SW   [kworker/u2:2]
  633 admin     250m S    ./hikdsp
  639 admin     1804 S    -/bin/psh
  640 admin     2244 S    init
  688 admin        0 SW   [RTW_CMD_THREAD]
 1086 admin     1796 S    dropbear -R -I 1800
 1222 admin        0 SW   [kworker/0:2]
 1231 admin        0 Z    [sh]
 1233 admin        0 Z    [sh]
 1304 admin     2080 S    dropbear -R -I 1800
 1307 admin     1808 S    -psh
 1321 admin     2244 S    {diag} /bin/bash /usr/sbin/diag wifi
 1327 admin     2248 R    ps
========ps -T========
    1 admin     2244 S    init
  574 admin     5972 S    {daemon_unix_bus} /home/process/daemon_fsp_app
  584 admin    20248 S    {-1_service_data} /home/process/database_process
  585 admin    20248 S    {pid578_recv_dat} /home/process/database_process
  586 admin    20248 S    {pid578_send_dat} /home/process/database_process
  598 admin    20248 S    {ipc_backup_cfg} /home/process/database_process
  587 admin    27516 S    {-1_service_net_} /home/process/net_process
  588 admin    27516 S    {pid579_recv_net} /home/process/net_process
  589 admin    27516 S    {pid579_send_net} /home/process/net_process
  664 admin    27516 S    {Dhcpv4c} /home/process/net_process
  691 admin    27516 S    {ipc_supplicant} /home/process/net_process
  692 admin    27516 S    {ipc_wifievent} /home/process/net_process
  693 admin    27516 S    {ipc_startwps} /home/process/net_process
  701 admin    27516 S    {ipc_wifi_scan} /home/process/net_process
  757 admin    27516 S    {netprocess_tran} /home/process/net_process
  594 admin     231m S    {-1_service_davi} /home/davinci
  595 admin     231m S    {pid593_recv_dav} /home/davinci
  596 admin     231m S    {pid593_send_dav} /home/davinci
  605 admin     231m S    {ipc_watchdog} /home/davinci
  606 admin     231m S    {ipc_reboot} /home/davinci
  662 admin     231m S    {ipc_mcuthread} /home/davinci
  663 admin     231m S    {ipc_usrSucurty} /home/davinci
  680 admin     231m S    {ipc_wifilink} /home/davinci
  681 admin     231m S    /home/davinci
  682 admin     231m S    {ipc_hdtaskctrl} /home/davinci
  683 admin     231m S    {ipc_dvrlogtask} /home/davinci
  684 admin     231m S    {ipc_Movelog} /home/davinci
  685 admin     231m S    {ipc_backuptask} /home/davinci
  686 admin     231m S    {ipc_sdctrl} /home/davinci
  687 admin     231m S    {nas_config_mana} /home/davinci
  700 admin     231m S    {ipc_record1} /home/davinci
  703 admin     231m S    {ipc_wlan0_sadp} /home/davinci
  706 admin     231m S    {user_onlinetask} /home/davinci
  707 admin     231m S    {ipc_recschdule} /home/davinci
  708 admin     231m S    {ipc_SdEmCrl} /home/davinci
  709 admin     231m S    {ipc_soundtask} /home/davinci
  710 admin     231m S    {ipc_exception} /home/davinci
  711 admin     231m S    {auto_defense_Ct} /home/davinci
  712 admin     231m S    {ipc_alarmInCtrl} /home/davinci
  713 admin     231m S    {ipc_pandatask} /home/davinci
  714 admin     231m S    {ipc_motDetCtr} /home/davinci
  715 admin     231m S    {motdect_modectl} /home/davinci
  716 admin     231m S    {ipc_smartDetCtr} /home/davinci
  717 admin     231m S    {ipc_alarmin} /home/davinci
  718 admin     231m S    {ipc_net_check} /home/davinci
  719 admin     231m S    {streamRecv} /home/davinci
  720 admin     231m S    {stream_recv1} /home/davinci
  721 admin     231m S    {ipc_alarmtohost} /home/davinci
  723 admin     231m S    {ipc_SdEmsrictl} /home/davinci
  729 admin     231m S    {ipc_rtcp_timer} /home/davinci
  731 admin     231m S    {ipc_dvrNetServ} /home/davinci
  732 admin     231m S    {isapi_Session} /home/davinci
  734 admin     231m S    {ipc_timeCtrl} /home/davinci
  735 admin     231m S    /home/davinci
  736 admin     231m S    {ipc_eth0_sadp} /home/davinci
  737 admin     231m S    {ipc_arptask} /home/davinci
  738 admin     231m S    {ipc_ContiCommd} /home/davinci
  739 admin     231m S    {ipc_nei_sol} /home/davinci
  740 admin     231m S    {ipc_sntptask} /home/davinci
  741 admin     231m S    {etimer_loop} /home/davinci
  742 admin     231m S    {ipc_ddns} /home/davinci
  743 admin     231m S    {ipc_bonjour} /home/davinci
  746 admin     231m S    {ipc_snmp} /home/davinci
  748 admin     231m S    {ipc_smtp} /home/davinci
  749 admin     231m S    {ipc_evttrigcap} /home/davinci
  750 admin     231m S    {ipc_timetrigcap} /home/davinci
  751 admin     231m S    {isp_schedule_ct} /home/davinci
  752 admin     231m S    {ipc_anr_task} /home/davinci
  753 admin     231m S    {ipc_appweb} /home/davinci
  754 admin     231m S    {events} /home/davinci
  755 admin     231m S    {ipc_svchandler} /home/davinci
  762 admin     231m S    {ipc_ICRctrl_0} /home/davinci
  763 admin     231m S    {ipc_wdr_Ctrl_0} /home/davinci
  765 admin     231m S    {OnvifServCtl} /home/davinci
  766 admin     231m S    {ezviz_daemon} /home/davinci
  767 admin     231m S    {is_dis_start} /home/davinci
  768 admin     231m S    {ipc_flash_log} /home/davinci
  769 admin     231m S    {ipc_maintain_lo} /home/davinci
  772 admin     231m S    {ezviz_online_ch} /home/davinci
  776 admin     231m S    {close_base_even} /home/davinci
  777 admin     231m S    {ipc_OnvifEvent} /home/davinci
  778 admin     231m S    {ipc_OnvifExcept} /home/davinci
  779 admin     231m S    {ipc_OnvifPTZ} /home/davinci
  780 admin     231m S    {onvif_probe_wla} /home/davinci
  781 admin     231m S    {hello_server_wl} /home/davinci
  783 admin     231m S    {is_multi_wifi} /home/davinci
  794 admin     231m S    {worker.00000004} /home/davinci
 1029 admin     231m S    {sdktcp54_61421} /home/davinci
 1030 admin     231m S    {ipc_PrevCtrl_54} /home/davinci
 1065 admin     231m S    {ipc_Session0} /home/davinci
 1066 admin     231m S    {rtsptcp43_61636} /home/davinci
 1146 admin     231m S    {worker.00000006} /home/davinci
  641 admin     250m S    ./hikdsp
  644 admin     250m S    {ipc_host_cmd} ./hikdsp
  645 admin     250m S    {ipc_bs_reader} ./hikdsp
  646 admin     250m S    {dsp_audio_input} ./hikdsp
  647 admin     250m S    {dsp_audio_encod} ./hikdsp
  648 admin     250m S    {ipc_Voicetalk} ./hikdsp
  649 admin     250m S    ./hikdsp
  650 admin     250m S    {ipc_audio_iad} ./hikdsp
  651 admin     250m S    {yuv_data_read} ./hikdsp
  652 admin     250m S    {ipc_mtd} ./hikdsp
  653 admin     250m S    {ipc_smd_process} ./hikdsp
  654 admin     250m S    {ipc_fd_main} ./hikdsp
  655 admin     250m S    {ipc_fd_upload} ./hikdsp
  656 admin     250m S    {text_osd_thread} ./hikdsp
  657 admin     250m S    {ipc_zoom} ./hikdsp
  658 admin     250m S    {ipc_vsnc_guard} ./hikdsp
  659 admin     250m S    {ipc_smart264} ./hikdsp
  660 admin     250m S    {ipc_smart264_se} ./hikdsp
  661 admin     250m S    {ipc_vin_trigger} ./hikdsp
  704 admin     250m S    ./hikdsp
 1231 admin        0 Z    [sh]
 1233 admin        0 Z    [sh]
 1328 admin     2248 R    ps -T
################################ wifi log collection ###################################
========getWifiInfo=====
wifi_support: 1
wifi_enable: 1
wifi_chip: Realtek
wifi_conn_status: 1
ap_info:
SSID=RumbleNET
sta's macaddr:0c:80:63:3b:aa:c6
driver_ver:
rtl8188eu v4.3.0.4_11485.20140519
build time: Apr 27 2018 10:24:38
===========wl ver=======
/usr/sbin/diag: line 217: wl: not found
==========ifconfig======
eth0      Link encap:Ethernet  HWaddr 44:47:CC:89:0A:8E
          inet addr:169.254.67.94  Bcast:169.254.255.255  Mask:255.255.0.0
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:27
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:13 errors:0 dropped:0 overruns:0 frame:0
          TX packets:13 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:2232 (2.1 KiB)  TX bytes:2232 (2.1 KiB)
sit0      Link encap:IPv6-in-IPv4
          NOARP  MTU:1480  Metric:1
wlan0     Link encap:Ethernet  HWaddr D4:B7:61:18:2C:33
          inet addr:192.168.1.47  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::d6b7:61ff:fe18:2c33/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:247180 errors:0 dropped:12519 overruns:0 frame:0
          TX packets:705871 errors:0 dropped:4 overruns:0 carrier:0
          RX bytes:25859402 (24.6 MiB)  TX bytes:1071970016 (1022.3 MiB)
==========wl status=====
===========lsmod========
Module                  Size  Used by    Tainted: P
alarm                   3309  0
smart_config            5889  0
8188eu                931768  1 smart_config
ov4689_mipi            25226  0
ak4954                 59547  1
snd_soc_amba_board      5160  3 ak4954
snd_soc_dummy           2939  0
snd_soc_ambarella_i2s     5629  2
event_notify            4398  3 alarm
ehci_ambarella          2450  0
ehci_hcd               48068  1 ehci_ambarella
usbcore               152089  4 8188eu,ehci_ambarella,ehci_hcd
hikio                 119863  3 ak4954
base                    9113  5 alarm,smart_config,ak4954,event_notify,hikio
watch                    993  0
ambad                   1745  0
ambhdmi                26254  0
ambdbus                 1702  0
ambtve                  1742  0
iav                   230559  5 ov4689_mipi
vout                   44260  4 ambhdmi,ambdbus,ambtve,iav
hw_timer                4672  1 iav
imgproc                18846  1 iav
dsplog                  4767  1 iav
dsp                    55859  4 iav,vout,imgproc,dsplog
msg                    72222  9 ov4689_mipi,ambhdmi,ambdbus,ambtve,iav,vout,imgproc,dsplog,dsp
[ 1611.349218] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.349235] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.349252] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.349260] ipc_wifievent   S 803ca64c     0   692      1 0x00000000
[ 1611.349281] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.349298] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.349315] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.349332] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.349350] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.349366] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.349376] ipc_startwps    S 803ca64c     0   693      1 0x00000000
[ 1611.349396] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.349413] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.349433] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.349450] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.349460] ipc_wifi_scan   S 803ca64c     0   701      1 0x00000000
[ 1611.349480] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.349497] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.349514] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.349531] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.349539] netprocess_tran S 803ca64c     0   757      1 0x00000000
[ 1611.349560] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.349577] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.349597] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.349614] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.349623] davinci         S 803ca64c     0   593      1 0x00000000
[ 1611.349643] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.349660] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.349678] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.349694] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.349702] -1_service_davi S 803ca64c     0   594      1 0x00000000
[ 1611.349724] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.349738] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.349754] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.349768] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.349784] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.349792] pid593_recv_dav S 803ca64c     0   595      1 0x00000000
[ 1611.349813] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.349832] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.349849] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.349866] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.349884] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.349902] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.349910] pid593_send_dav S 803ca64c     0   596      1 0x00000000
[ 1611.349931] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.349945] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.349960] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.349975] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.349990] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.349998] ipc_watchdog    S 803ca64c     0   605      1 0x00000000
[ 1611.350018] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.350038] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.350056] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.350075] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350083] ipc_reboot      S 803ca64c     0   606      1 0x00000000
[ 1611.350104] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.350122] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.350139] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.350156] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350163] ipc_mcuthread   S 803ca64c     0   662      1 0x00000000
[ 1611.350184] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.350200] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.350218] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.350235] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350242] ipc_usrSucurty  S 803ca64c     0   663      1 0x00000000
[ 1611.350264] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.350280] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.350297] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.350314] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350322] ipc_wifilink    S 803ca64c     0   680      1 0x00000000
[ 1611.350341] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.350358] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.350376] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.350393] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350400] davinci         S 803ca64c     0   681      1 0x00000000
[ 1611.350421] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c947c>] (schedule_timeout+0x15c/0x1bc)
[ 1611.350441] [<803c947c>] (schedule_timeout+0x15c/0x1bc) from [<802dfff4>] (__skb_recv_datagram+0x2bc/0x380)
[ 1611.350459] [<802dfff4>] (__skb_recv_datagram+0x2bc/0x380) from [<802e00e8>] (skb_recv_datagram+0x30/0x38)
[ 1611.350480] [<802e00e8>] (skb_recv_datagram+0x30/0x38) from [<8036a004>] (unix_accept+0x58/0x184)
[ 1611.350499] [<8036a004>] (unix_accept+0x58/0x184) from [<802d5878>] (SyS_accept4+0xc4/0x1c0)
[ 1611.350516] [<802d5878>] (SyS_accept4+0xc4/0x1c0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350524] ipc_hdtaskctrl  S 803ca64c     0   682      1 0x00000000
[ 1611.350547] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.350573] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.350595] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.350613] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350623] ipc_dvrlogtask  S 803ca64c     0   683      1 0x00000000
[ 1611.350645] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.350662] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.350678] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.350695] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350702] ipc_Movelog     S 803ca64c     0   684      1 0x00000000
[ 1611.350723] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140)
[ 1611.350740] [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.350758] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.350776] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350783] ipc_backuptask  S 803ca64c     0   685      1 0x00000000
[ 1611.350805] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.350822] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.350838] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.350854] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350862] ipc_sdctrl      S 803ca64c     0   686      1 0x00000000
[ 1611.350882] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.350903] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.350922] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.350939] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.350947] nas_config_mana S 803ca64c     0   687      1 0x00000000
[ 1611.350968] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.350988] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.351007] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.351024] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351033] ipc_record1     S 803ca64c     0   700      1 0x00000000
[ 1611.351056] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140)
[ 1611.351073] [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.351090] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.351107] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351116] ipc_wlan0_sadp  S 803ca64c     0   703      1 0x00000000
[ 1611.351139] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.351161] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.351180] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.351198] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.351215] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.351235] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351243] user_onlinetask S 803ca64c     0   706      1 0x00000000
[ 1611.351264] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.351283] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.351301] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.351318] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351325] ipc_recschdule  S 803ca64c     0   707      1 0x00000000
[ 1611.351347] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.351363] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.351380] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.351399] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351406] ipc_SdEmCrl     S 803ca64c     0   708      1 0x00000000
[ 1611.351428] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140)
[ 1611.351446] [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.351462] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.351479] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351487] ipc_soundtask   S 803ca64c     0   709      1 0x00000000
[ 1611.351509] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.351526] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.351545] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.351562] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351570] ipc_exception   S 803ca64c     0   710      1 0x00000000
[ 1611.351592] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.351610] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.351627] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.351644] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351653] auto_defense_Ct S 803ca64c     0   711      1 0x00000000
[ 1611.351675] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.351695] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.351713] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.351733] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351741] ipc_alarmInCtrl S 803ca64c     0   712      1 0x00000000
[ 1611.351762] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.351781] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.351799] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.351817] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351827] ipc_pandatask   S 803ca64c     0   713      1 0x00000000
[ 1611.351850] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.351867] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.351882] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.351899] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.351906] ipc_motDetCtr   S 803ca64c     0   714      1 0x00000000
[ 1611.351930] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.351946] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.351962] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.351977] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.351993] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.352001] motdect_modectl S 803ca64c     0   715      1 0x00000000
[ 1611.352023] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.352037] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.352051] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.352065] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.352081] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.352089] ipc_smartDetCtr S 803ca64c     0   716      1 0x00000000
[ 1611.352111] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.352127] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.352143] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.352157] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.352173] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.352182] ipc_alarmin     S 803ca64c     0   717      1 0x00000000
[ 1611.352208] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.352230] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.352249] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.352268] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.352286] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.352304] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.352313] ipc_net_check   S 803ca64c     0   718      1 0x00000000
[ 1611.352337] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.352356] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.352378] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.352396] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.352405] streamRecv      R running      0   719      1 0x00000000
[ 1611.352428] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.352448] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.352466] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.352483] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.352493] stream_recv1    S 803ca64c     0   720      1 0x00000000
[ 1611.352517] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.352534] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.352552] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.352570] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.352579] ipc_alarmtohost S 803ca64c     0   721      1 0x00000000
[ 1611.352603] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140)
[ 1611.352621] [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.352638] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.352655] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.352664] ipc_SdEmsrictl  S 803ca64c     0   723      1 0x00000000
[ 1611.352688] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.352702] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.352718] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.352734] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.352750] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.352759] ipc_rtcp_timer  S 803ca64c     0   729      1 0x00000000
[ 1611.352780] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.352802] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.352822] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.352840] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.352848] ipc_dvrNetServ  S 803ca64c     0   731      1 0x00000000
[ 1611.352873] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c947c>] (schedule_timeout+0x15c/0x1bc)
[ 1611.352916] [<803c947c>] (schedule_timeout+0x15c/0x1bc) from [<8031f900>] (inet_csk_accept+0x1dc/0x230)
[ 1611.352950] [<8031f900>] (inet_csk_accept+0x1dc/0x230) from [<803467e4>] (inet_accept+0x30/0xdc)
[ 1611.352972] [<803467e4>] (inet_accept+0x30/0xdc) from [<802d5878>] (SyS_accept4+0xc4/0x1c0)
[ 1611.352993] [<802d5878>] (SyS_accept4+0xc4/0x1c0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353002] isapi_Session   S 803ca64c     0   732      1 0x00000000
[ 1611.353026] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.353045] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.353065] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.353082] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353091] ipc_timeCtrl    S 803ca64c     0   734      1 0x00000000
[ 1611.353115] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.353136] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.353155] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.353173] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353181] davinci         S 803ca64c     0   735      1 0x00000000
[ 1611.353231] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80033e68>] (sys_pause+0x34/0x54)
[ 1611.353252] [<80033e68>] (sys_pause+0x34/0x54) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353260] ipc_eth0_sadp   S 803ca64c     0   736      1 0x00000000
[ 1611.353285] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.353309] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.353328] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.353346] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.353364] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.353382] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353391] ipc_arptask     S 803ca64c     0   737      1 0x00000000
[ 1611.353415] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.353435] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.353453] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.353471] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.353489] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.353507] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353515] ipc_ContiCommd  S 803ca64c     0   738      1 0x00000000
[ 1611.353539] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.353555] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.353571] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.353588] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.353605] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353613] ipc_nei_sol     S 803ca64c     0   739      1 0x00000000
[ 1611.353636] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.353659] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.353677] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.353696] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353704] ipc_sntptask    S 803ca64c     0   740      1 0x00000000
[ 1611.353726] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.353744] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.353763] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.353781] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353789] etimer_loop     S 803ca64c     0   741      1 0x00000000
[ 1611.353812] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.353830] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.353848] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.353865] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353873] ipc_ddns        S 803ca64c     0   742      1 0x00000000
[ 1611.353897] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.353915] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.353934] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.353950] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.353959] ipc_bonjour     S 803ca64c     0   743      1 0x00000000
[ 1611.353982] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.354001] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.354019] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.354036] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.354044] ipc_snmp        S 803ca64c     0   746      1 0x00000000
[ 1611.354067] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.354086] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.354105] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.354123] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.354144] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.354162] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.354170] ipc_smtp        S 803ca64c     0   748      1 0x00000000
[ 1611.354194] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.354208] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.354224] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.354239] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.354255] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.354263] ipc_evttrigcap  S 803ca64c     0   749      1 0x00000000
[ 1611.354285] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.354303] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.354322] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.354340] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.354351] ipc_timetrigcap S 803ca64c     0   750      1 0x00000000
[ 1611.354372] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.354389] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.354407] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.354425] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.354434] isp_schedule_ct S 803ca64c     0   751      1 0x00000000
[ 1611.354456] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.354473] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.354491] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.354510] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.354518] ipc_anr_task    S 803ca64c     0   752      1 0x00000000
[ 1611.354541] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.354562] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.354580] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.354599] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.354610] ipc_appweb      S 803ca64c     0   753      1 0x00000000
[ 1611.354634] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.354650] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.354669] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.354686] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.354698] events          S 803ca64c     0   754      1 0x00000000
[ 1611.354723] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.354747] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.354766] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800ba45c>] (do_sys_poll+0x308/0x3c0)
[ 1611.354785] [<800ba45c>] (do_sys_poll+0x308/0x3c0) from [<800ba5c0>] (SyS_poll+0x5c/0xd4)
[ 1611.354801] [<800ba5c0>] (SyS_poll+0x5c/0xd4) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.354809] ipc_svchandler  S 803ca64c     0   755      1 0x00000000
[ 1611.354833] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.354852] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.354870] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.354887] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.354905] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.354924] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.354934] ipc_ICRctrl_0   S 803ca64c     0   762      1 0x00000000
[ 1611.354958] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.354981] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.355001] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.355018] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355027] ipc_wdr_Ctrl_0  S 803ca64c     0   763      1 0x00000000
[ 1611.355050] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.355068] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.355087] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.355104] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355111] OnvifServCtl    S 803ca64c     0   765      1 0x00000000
[ 1611.355134] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.355152] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.355171] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.355189] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355198] ezviz_daemon    S 803ca64c     0   766      1 0x00000000
[ 1611.355218] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.355237] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.355257] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.355274] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355282] is_dis_start    S 803ca64c     0   767      1 0x00000000
[ 1611.355305] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.355323] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.355342] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.355359] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355367] ipc_flash_log   S 803ca64c     0   768      1 0x00000000
[ 1611.355393] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140)
[ 1611.355413] [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.355430] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.355447] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355456] ipc_maintain_lo S 803ca64c     0   769      1 0x00000000
[ 1611.355479] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140)
[ 1611.355498] [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.355517] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.355535] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355543] ezviz_online_ch S 803ca64c     0   772      1 0x00000000
[ 1611.355566] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.355586] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.355604] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.355626] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355634] close_base_even S 803ca64c     0   776      1 0x00000000
[ 1611.355659] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.355674] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.355690] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.355705] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.355723] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355732] ipc_OnvifEvent  S 803ca64c     0   777      1 0x00000000
[ 1611.355755] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.355775] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.355794] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.355813] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355820] ipc_OnvifExcept S 803ca64c     0   778      1 0x00000000
[ 1611.355843] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.355860] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.355879] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.355896] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355904] ipc_OnvifPTZ    S 803ca64c     0   779      1 0x00000000
[ 1611.355928] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.355946] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.355964] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.355981] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.355988] onvif_probe_wla S 803ca64c     0   780      1 0x00000000
[ 1611.356012] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140)
[ 1611.356035] [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.356053] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.356072] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.356090] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.356110] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.356118] hello_server_wl S 803ca64c     0   781      1 0x00000000
[ 1611.356144] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140)
[ 1611.356161] [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140) from [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4)
[ 1611.356180] [<8019e8fc>] (wq_sleep.constprop.21+0xe8/0x1e4) from [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8)
[ 1611.356198] [<8019f394>] (SyS_mq_timedreceive+0x2ec/0x4b8) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.356205] is_multi_wifi   S 803ca64c     0   783      1 0x00000000
[ 1611.356227] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.356246] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.356264] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.356282] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.356302] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.356320] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.356329] worker.00000004 S 803ca64c     0   794      1 0x00000000
[ 1611.356353] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.356369] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.356386] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.356401] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.356417] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.356425] sdktcp54_61421  S 803ca64c     0  1029      1 0x00000000
[ 1611.356450] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c945c>] (schedule_timeout+0x13c/0x1bc)
[ 1611.356475] [<803c945c>] (schedule_timeout+0x13c/0x1bc) from [<802e11b0>] (sk_stream_wait_memory+0x1bc/0x224)
[ 1611.356514] [<802e11b0>] (sk_stream_wait_memory+0x1bc/0x224) from [<80323258>] (tcp_sendmsg+0x708/0xc84)
[ 1611.356539] [<80323258>] (tcp_sendmsg+0x708/0xc84) from [<802d4628>] (sock_aio_write+0x10c/0x138)
[ 1611.356579] [<802d4628>] (sock_aio_write+0x10c/0x138) from [<800a76f0>] (do_sync_readv_writev+0x74/0x9c)
[ 1611.356603] [<800a76f0>] (do_sync_readv_writev+0x74/0x9c) from [<800a8680>] (do_readv_writev+0xbc/0x22c)
[ 1611.356622] [<800a8680>] (do_readv_writev+0xbc/0x22c) from [<800a88b4>] (vfs_writev+0x4c/0x78)
[ 1611.356639] [<800a88b4>] (vfs_writev+0x4c/0x78) from [<800a8994>] (SyS_writev+0x3c/0x78)
[ 1611.356660] [<800a8994>] (SyS_writev+0x3c/0x78) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.356669] ipc_PrevCtrl_54 S 803ca64c     0  1030      1 0x00000000
[ 1611.356699] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.356719] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.356738] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.356758] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.356776] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.356794] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.356802] ipc_Session0    S 803ca64c     0  1065      1 0x00000000
[ 1611.356826] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.356845] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.356863] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.356881] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.356899] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.356917] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.356925] rtsptcp43_61636 S 803ca64c     0  1066      1 0x00000000
[ 1611.356950] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c945c>] (schedule_timeout+0x13c/0x1bc)
[ 1611.356969] [<803c945c>] (schedule_timeout+0x13c/0x1bc) from [<802e11b0>] (sk_stream_wait_memory+0x1bc/0x224)
[ 1611.356994] [<802e11b0>] (sk_stream_wait_memory+0x1bc/0x224) from [<80323258>] (tcp_sendmsg+0x708/0xc84)
[ 1611.357017] [<80323258>] (tcp_sendmsg+0x708/0xc84) from [<802d4628>] (sock_aio_write+0x10c/0x138)
[ 1611.357035] [<802d4628>] (sock_aio_write+0x10c/0x138) from [<800a76f0>] (do_sync_readv_writev+0x74/0x9c)
[ 1611.357053] [<800a76f0>] (do_sync_readv_writev+0x74/0x9c) from [<800a8680>] (do_readv_writev+0xbc/0x22c)
[ 1611.357069] [<800a8680>] (do_readv_writev+0xbc/0x22c) from [<800a88b4>] (vfs_writev+0x4c/0x78)
[ 1611.357086] [<800a88b4>] (vfs_writev+0x4c/0x78) from [<800a8994>] (SyS_writev+0x3c/0x78)
[ 1611.357106] [<800a8994>] (SyS_writev+0x3c/0x78) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.357115] worker.00000006 S 803ca64c     0  1146      1 0x00000000
[ 1611.357139] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.357154] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.357171] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.357187] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.357205] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.357214] kworker/u2:2    S 803ca64c     0   597      2 0x00000000
[ 1611.357271] [<803ca64c>] (__schedule+0x1bc/0x428) from [<8003b2dc>] (worker_thread+0x22c/0x458)
[ 1611.357293] [<8003b2dc>] (worker_thread+0x22c/0x458) from [<80040d98>] (kthread+0xb4/0xb8)
[ 1611.357310] [<80040d98>] (kthread+0xb4/0xb8) from [<8000ead8>] (ret_from_fork+0x14/0x3c)
[ 1611.357319] hikdsp          S 803ca64c     0   633      1 0x00000000
[ 1611.357341] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.357363] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.357384] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.357402] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.357410] hikdsp          S 803ca64c     0   641      1 0x00000000
[ 1611.357433] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c947c>] (schedule_timeout+0x15c/0x1bc)
[ 1611.357457] [<803c947c>] (schedule_timeout+0x15c/0x1bc) from [<802dfff4>] (__skb_recv_datagram+0x2bc/0x380)
[ 1611.357475] [<802dfff4>] (__skb_recv_datagram+0x2bc/0x380) from [<802e00e8>] (skb_recv_datagram+0x30/0x38)
[ 1611.357514] [<802e00e8>] (skb_recv_datagram+0x30/0x38) from [<802ff9ec>] (netlink_recvmsg+0x3c/0x2d0)
[ 1611.357540] [<802ff9ec>] (netlink_recvmsg+0x3c/0x2d0) from [<802d3b40>] (sock_recvmsg+0x84/0xa8)
[ 1611.357563] [<802d3b40>] (sock_recvmsg+0x84/0xa8) from [<802d4bec>] (___sys_recvmsg.part.31+0xd8/0x190)
[ 1611.357587] [<802d4bec>] (___sys_recvmsg.part.31+0xd8/0x190) from [<802d6178>] (__sys_recvmsg+0x50/0x80)
[ 1611.357605] [<802d6178>] (__sys_recvmsg+0x50/0x80) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.357613] ipc_host_cmd    S 803ca64c     0   644      1 0x00000000
[ 1611.357667] [<803ca64c>] (__schedule+0x1bc/0x428) from [<8019b424>] (SyS_semtimedop+0x7bc/0xc40)
[ 1611.357691] [<8019b424>] (SyS_semtimedop+0x7bc/0xc40) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.357700] ipc_bs_reader   S 803ca64c     0   645      1 0x00000000
[ 1611.357864] [<803ca64c>] (__schedule+0x1bc/0x428) from [<7f069fb4>] (iav_query_framedesc+0x19c/0x3d4 [iav])
[ 1611.357964] [<7f069fb4>] (iav_query_framedesc+0x19c/0x3d4 [iav]) from [<7f06a35c>] (iav_ioc_g_query_desc+0xec/0x428 [iav])
[ 1611.358043] [<7f06a35c>] (iav_ioc_g_query_desc+0xec/0x428 [iav]) from [<7f05f748>] (iav_encode_ioctl+0x620/0x1868 [iav])
[ 1611.358102] [<7f05f748>] (iav_encode_ioctl+0x620/0x1868 [iav]) from [<7f052cfc>] (iav_ioctl+0x12c/0x2ac [iav])
[ 1611.358149] [<7f052cfc>] (iav_ioctl+0x12c/0x2ac [iav]) from [<800b8860>] (do_vfs_ioctl+0x418/0x5e8)
[ 1611.358172] [<800b8860>] (do_vfs_ioctl+0x418/0x5e8) from [<800b8a68>] (SyS_ioctl+0x38/0x60)
[ 1611.358195] [<800b8a68>] (SyS_ioctl+0x38/0x60) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.358205] dsp_audio_input S 803ca64c     0   646      1 0x00000000
[ 1611.358236] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140)
[ 1611.358256] [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.358276] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800ba45c>] (do_sys_poll+0x308/0x3c0)
[ 1611.358294] [<800ba45c>] (do_sys_poll+0x308/0x3c0) from [<800ba5c0>] (SyS_poll+0x5c/0xd4)
[ 1611.358311] [<800ba5c0>] (SyS_poll+0x5c/0xd4) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.358319] dsp_audio_encod S 803ca64c     0   647      1 0x00000000
[ 1611.358342] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.358368] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.358387] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.358405] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.358412] ipc_Voicetalk   S 803ca64c     0   648      1 0x00000000
[ 1611.358433] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.358452] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.358470] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.358489] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.358497] hikdsp          S 803ca64c     0   649      1 0x00000000
[ 1611.358519] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.358536] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.358554] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.358573] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.358582] ipc_audio_iad   R running      0   650      1 0x00000000
[ 1611.358606] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.358624] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.358643] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.358660] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.358667] yuv_data_read   S 803ca64c     0   651      1 0x00000000
[ 1611.358691] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.358706] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.358723] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.358738] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.358757] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.358765] ipc_mtd         S 803ca64c     0   652      1 0x00000000
[ 1611.358788] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.358805] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.358824] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.358841] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.358851] ipc_smd_process S 803ca64c     0   653      1 0x00000000
[ 1611.358872] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.358889] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.358908] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.358926] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.358934] ipc_fd_main     S 803ca64c     0   654      1 0x00000000
[ 1611.358958] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.358978] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.358997] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.359014] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.359027] ipc_fd_upload   S 803ca64c     0   655      1 0x00000000
[ 1611.359052] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80059da4>] (futex_wait_queue_me+0xfc/0x12c)
[ 1611.359068] [<80059da4>] (futex_wait_queue_me+0xfc/0x12c) from [<8005a9ec>] (futex_wait+0x188/0x264)
[ 1611.359086] [<8005a9ec>] (futex_wait+0x188/0x264) from [<8005c60c>] (do_futex+0x100/0xbb4)
[ 1611.359102] [<8005c60c>] (do_futex+0x100/0xbb4) from [<8005d140>] (SyS_futex+0x80/0x160)
[ 1611.359120] [<8005d140>] (SyS_futex+0x80/0x160) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.359130] text_osd_thread R running      0   656      1 0x00000000
[ 1611.359150] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.359170] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.359190] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.359207] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.359217] ipc_zoom        S 803ca64c     0   657      1 0x00000000
[ 1611.359240] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.359258] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.359278] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.359294] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.359302] ipc_vsnc_guard  S 803ca64c     0   658      1 0x00000000
[ 1611.359325] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c947c>] (schedule_timeout+0x15c/0x1bc)
[ 1611.359351] [<803c947c>] (schedule_timeout+0x15c/0x1bc) from [<802dfff4>] (__skb_recv_datagram+0x2bc/0x380)
[ 1611.359370] [<802dfff4>] (__skb_recv_datagram+0x2bc/0x380) from [<802e00e8>] (skb_recv_datagram+0x30/0x38)
[ 1611.359396] [<802e00e8>] (skb_recv_datagram+0x30/0x38) from [<802ff9ec>] (netlink_recvmsg+0x3c/0x2d0)
[ 1611.359421] [<802ff9ec>] (netlink_recvmsg+0x3c/0x2d0) from [<802d3b40>] (sock_recvmsg+0x84/0xa8)
[ 1611.359441] [<802d3b40>] (sock_recvmsg+0x84/0xa8) from [<802d4bec>] (___sys_recvmsg.part.31+0xd8/0x190)
[ 1611.359464] [<802d4bec>] (___sys_recvmsg.part.31+0xd8/0x190) from [<802d6178>] (__sys_recvmsg+0x50/0x80)
[ 1611.359481] [<802d6178>] (__sys_recvmsg+0x50/0x80) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.359489] ipc_smart264    S 803ca64c     0   659      1 0x00000000
[ 1611.359510] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c945c>] (schedule_timeout+0x13c/0x1bc)
[ 1611.359532] [<803c945c>] (schedule_timeout+0x13c/0x1bc) from [<8001beb0>] (ambsync_proc_read+0xe8/0x1b0)
[ 1611.359560] [<8001beb0>] (ambsync_proc_read+0xe8/0x1b0) from [<800f6674>] (proc_reg_read+0x50/0x78)
[ 1611.359590] [<800f6674>] (proc_reg_read+0x50/0x78) from [<800a7c6c>] (vfs_read+0x98/0x144)
[ 1611.359612] [<800a7c6c>] (vfs_read+0x98/0x144) from [<800a82cc>] (SyS_read+0x3c/0x78)
[ 1611.359629] [<800a82cc>] (SyS_read+0x3c/0x78) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.359638] ipc_smart264_se S 803ca64c     0   660      1 0x00000000
[ 1611.359661] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c9eb4>] (do_nanosleep+0x80/0xd8)
[ 1611.359681] [<803c9eb4>] (do_nanosleep+0x80/0xd8) from [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108)
[ 1611.359699] [<80044f0c>] (hrtimer_nanosleep+0x8c/0x108) from [<80045028>] (SyS_nanosleep+0xa0/0xb0)
[ 1611.359716] [<80045028>] (SyS_nanosleep+0xa0/0xb0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.359725] ipc_vin_trigger S 803ca64c     0   661      1 0x00000000
[ 1611.359748] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c945c>] (schedule_timeout+0x13c/0x1bc)
[ 1611.359763] [<803c945c>] (schedule_timeout+0x13c/0x1bc) from [<8001beb0>] (ambsync_proc_read+0xe8/0x1b0)
[ 1611.359781] [<8001beb0>] (ambsync_proc_read+0xe8/0x1b0) from [<800f6674>] (proc_reg_read+0x50/0x78)
[ 1611.359799] [<800f6674>] (proc_reg_read+0x50/0x78) from [<800a7c6c>] (vfs_read+0x98/0x144)
[ 1611.359815] [<800a7c6c>] (vfs_read+0x98/0x144) from [<800a82cc>] (SyS_read+0x3c/0x78)
[ 1611.359831] [<800a82cc>] (SyS_read+0x3c/0x78) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.359840] hikdsp          S 803ca64c     0   704      1 0x00000000
[ 1611.359887] [<803ca64c>] (__schedule+0x1bc/0x428) from [<7f0310e4>] (img_get_statistics+0xe4/0x7cc [imgproc])
[ 1611.359922] [<7f0310e4>] (img_get_statistics+0xe4/0x7cc [imgproc]) from [<7f032a88>] (amba_imgproc_cmd+0x708/0x239c [imgproc])
[ 1611.359990] [<7f032a88>] (amba_imgproc_cmd+0x708/0x239c [imgproc]) from [<7f052de0>] (iav_ioctl+0x210/0x2ac [iav])
[ 1611.360045] [<7f052de0>] (iav_ioctl+0x210/0x2ac [iav]) from [<800b8860>] (do_vfs_ioctl+0x418/0x5e8)
[ 1611.360066] [<800b8860>] (do_vfs_ioctl+0x418/0x5e8) from [<800b8a68>] (SyS_ioctl+0x38/0x60)
[ 1611.360087] [<800b8a68>] (SyS_ioctl+0x38/0x60) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.360097] psh             S 803ca64c     0   639      1 0x00000000
[ 1611.360123] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c947c>] (schedule_timeout+0x15c/0x1bc)
[ 1611.360144] [<803c947c>] (schedule_timeout+0x15c/0x1bc) from [<80041534>] (wait_woken+0x30/0x50)
[ 1611.360173] [<80041534>] (wait_woken+0x30/0x50) from [<80208d50>] (n_tty_read+0x1fc/0x854)
[ 1611.360195] [<80208d50>] (n_tty_read+0x1fc/0x854) from [<80203bac>] (tty_read+0x7c/0xcc)
[ 1611.360214] [<80203bac>] (tty_read+0x7c/0xcc) from [<800a7c6c>] (vfs_read+0x98/0x144)
[ 1611.360230] [<800a7c6c>] (vfs_read+0x98/0x144) from [<800a82cc>] (SyS_read+0x3c/0x78)
[ 1611.360248] [<800a82cc>] (SyS_read+0x3c/0x78) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.360258] init            S 803ca64c     0   640      1 0x00000000
[ 1611.360282] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c947c>] (schedule_timeout+0x15c/0x1bc)
[ 1611.360301] [<803c947c>] (schedule_timeout+0x15c/0x1bc) from [<80041534>] (wait_woken+0x30/0x50)
[ 1611.360316] [<80041534>] (wait_woken+0x30/0x50) from [<80208d50>] (n_tty_read+0x1fc/0x854)
[ 1611.360331] [<80208d50>] (n_tty_read+0x1fc/0x854) from [<80203bac>] (tty_read+0x7c/0xcc)
[ 1611.360350] [<80203bac>] (tty_read+0x7c/0xcc) from [<800a7c6c>] (vfs_read+0x98/0x144)
[ 1611.360365] [<800a7c6c>] (vfs_read+0x98/0x144) from [<800a82cc>] (SyS_read+0x3c/0x78)
[ 1611.360383] [<800a82cc>] (SyS_read+0x3c/0x78) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.360391] RTW_CMD_THREAD  S 803ca64c     0   688      2 0x00000000
[ 1611.360414] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803c947c>] (schedule_timeout+0x15c/0x1bc)
[ 1611.360431] [<803c947c>] (schedule_timeout+0x15c/0x1bc) from [<803ca244>] (__down_interruptible+0xb0/0xf4)
[ 1611.360449] [<803ca244>] (__down_interruptible+0xb0/0xf4) from [<80045d14>] (down_interruptible+0x7c/0x90)
[ 1611.361028] [<80045d14>] (down_interruptible+0x7c/0x90) from [<7f19963c>] (_rtw_down_sema+0x8/0x14 [8188eu])
[ 1611.361422] [<7f19963c>] (_rtw_down_sema+0x8/0x14 [8188eu]) from [<7f15da24>] (rtw_cmd_thread+0x84/0x428 [8188eu])
[ 1611.361556] [<7f15da24>] (rtw_cmd_thread+0x84/0x428 [8188eu]) from [<80040d98>] (kthread+0xb4/0xb8)
[ 1611.361588] [<80040d98>] (kthread+0xb4/0xb8) from [<8000ead8>] (ret_from_fork+0x14/0x3c)
[ 1611.361599] dropbear        S 803ca64c     0  1086      1 0x00000000
[ 1611.361633] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140)
[ 1611.361666] [<803ca0a0>] (schedule_hrtimeout_range_clock+0x124/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.361685] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.361703] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.361720] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.361741] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.361749] dropbear        S 803ca64c     0  1094   1086 0x00000000
[ 1611.361772] [<803ca64c>] (__schedule+0x1bc/0x428) from [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140)
[ 1611.361791] [<803ca030>] (schedule_hrtimeout_range_clock+0xb4/0x140) from [<800b90a0>] (poll_schedule_timeout+0x38/0x58)
[ 1611.361809] [<800b90a0>] (poll_schedule_timeout+0x38/0x58) from [<800b995c>] (do_select+0x4b4/0x55c)
[ 1611.361829] [<800b995c>] (do_select+0x4b4/0x55c) from [<800b9b30>] (core_sys_select+0x12c/0x328)
[ 1611.361846] [<800b9b30>] (core_sys_select+0x12c/0x328) from [<800b9df0>] (SyS_select+0xc4/0x110)
[ 1611.361863] [<800b9df0>] (SyS_select+0xc4/0x110) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.361872] psh             S 803ca64c     0  1097   1094 0x00000000
[ 1611.361908] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80027328>] (do_wait+0x210/0x230)
[ 1611.361930] [<80027328>] (do_wait+0x210/0x230) from [<80027770>] (SyS_wait4+0x5c/0xc0)
[ 1611.361947] [<80027770>] (SyS_wait4+0x5c/0xc0) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
[ 1611.361955] kworker/0:2     R running      0  1222      2 0x00000000
[ 1611.362005] [<803ca64c>] (__schedule+0x1bc/0x428) from [<8003b2dc>] (worker_thread+0x22c/0x458)
[ 1611.362026] [<8003b2dc>] (worker_thread+0x22c/0x458) from [<80040d98>] (kthread+0xb4/0xb8)
[ 1611.362043] [<80040d98>] (kthread+0xb4/0xb8) from [<8000ead8>] (ret_from_fork+0x14/0x3c)
[ 1611.362050] sh              x 803ca64c     0  1231    681 0x00000004
[ 1611.362074] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80026318>] (do_exit+0x65c/0x914)
[ 1611.362092] [<80026318>] (do_exit+0x65c/0x914) from [<800274bc>] (do_group_exit+0x40/0xdc)
[ 1611.362111] [<800274bc>] (do_group_exit+0x40/0xdc) from [<80027568>] (__wake_up_parent+0x0/0x18)
[ 1611.362120] sh              x 803ca64c     0  1233    681 0x00000004
[ 1611.362142] [<803ca64c>] (__schedule+0x1bc/0x428) from [<80026318>] (do_exit+0x65c/0x914)
[ 1611.362159] [<80026318>] (do_exit+0x65c/0x914) from [<800274bc>] (do_group_exit+0x40/0xdc)
[ 1611.362176] [<800274bc>] (do_group_exit+0x40/0xdc) from [<80027568>] (__wake_up_parent+0x0/0x18)
[ 1611.362184] diag            R running      0  1247   1097 0x00000000
[ 1611.362218] [<80013108>] (unwind_backtrace+0x0/0x134) from [<8001176c>] (show_stack+0x10/0x14)
[ 1611.362258] [<8001176c>] (show_stack+0x10/0x14) from [<8004b5c8>] (show_state_filter+0x64/0x8c)
[ 1611.362295] [<8004b5c8>] (show_state_filter+0x64/0x8c) from [<8020eed4>] (__handle_sysrq+0xc0/0x1ac)
[ 1611.362316] [<8020eed4>] (__handle_sysrq+0xc0/0x1ac) from [<8020f3c4>] (write_sysrq_trigger+0x38/0x48)
[ 1611.362339] [<8020f3c4>] (write_sysrq_trigger+0x38/0x48) from [<800f65fc>] (proc_reg_write+0x50/0x78)
[ 1611.362364] [<800f65fc>] (proc_reg_write+0x50/0x78) from [<800a7dcc>] (vfs_write+0xb4/0x194)
[ 1611.362382] [<800a7dcc>] (vfs_write+0xb4/0x194) from [<800a8344>] (SyS_write+0x3c/0x78)
[ 1611.362400] [<800a8344>] (SyS_write+0x3c/0x78) from [<8000ea40>] (ret_fast_syscall+0x0/0x30)
Upon closer inspection today I realized that one solder connection came loose, probably when I was putting camera back together. After re-soldering and a bit of hot glue later, behold the result.
Code:
[  4] local 192.168.1.1 port 5001 connected with 192.168.1.47 port 45968
[ ID] Interval       Transfer     Bandwidth
[  4]  0.0-10.2 sec  39.0 MBytes  32.1 Mbits/sec
[  5] local 192.168.1.1 port 5001 connected with 192.168.1.47 port 45969
[  5]  0.0-10.1 sec  40.6 MBytes  33.7 Mbits/sec
[  4] local 192.168.1.1 port 5001 connected with 192.168.1.47 port 45970
[  4]  0.0-10.0 sec  39.9 MBytes  33.3 Mbits/sec
[  5] local 192.168.1.1 port 5001 connected with 192.168.1.47 port 45971
[  5]  0.0-10.1 sec  32.4 MBytes  32.8 Mbits/sec
[  4] local 192.168.1.1 port 5001 connected with 192.168.1.47 port 45972
[  4]  0.0-10.1 sec  39.0 MBytes  32.5 Mbits/sec
So far I can only guess that original antenna does as good as no antenna or the half-ass soldered antenna, because orignal untouched camera which is closer to access point still does only 1-2 Mbit/s in IPERF.
Going to replace antenna on the second one and report again.
