- Aug 17, 2015
- 4
- 0
New to the forum here. Just installed an outdoor PTZ wireless camera (HooToo HT-IP008HDP) that works fine for about a week or so then goes off line and will not connect through wifi. I assume every wifi cam requires you to run your CAT 5 cable back to the camera from the router to set up the wifi (WPS with password) since there are no "controls" on the camera to interact directly with wifi?
This is a huge PITA except that I did mount it close to the front door, and made the connections accessible in a covered electrical box and my 50 foot cable reaches the router I the office easily. Is there any other way to reconnect it without running the hard wire each time?
Thanks
Thanks
