good day. I am installing Hikvision¹ wifi cameras in a home. 3 cams are within router range, but the 4th is in a garage about 50 feet from the main house made of block. I had thought about using an AP and hoping 2.4 would penetrate the block for the camera but instead decided to go with powerline to the inside of the bay, into a wireless router set as AP to pick up the cam. Thats my plan, will it work?
The garage feeds from the house panel and does have a secondary sub panel in the garage which I don't think should cause an issue. Can I get your thoughts please.
Thx in advance
Thx in advance
