- Dec 3, 2016
- 25
- 10
Hi, Blue Iris been working flawlessly with 3 cameras on 2.4ghz (720p) and 1 phone camera on 5ghz. I also had 1 camera on a extender. The extender I fastlane a 5ghz connection and send out a 2.4ghz signal. I currently have the Nighthawk x6 and it really has been rock solid.
Where it went wrong was I decided to remove any blind spots and add 3 additional 1080p wifi cameras. Sometimes everything is happy and it works great. Sometimes cameras just start dropping for no apparent reason. In 30mins or so they will start working magically again. At this point I have 3 cameras on the repeater. I have 4 2.4ghz cameras on the router.
Most of the drops occur on the router. The router has 35-40 devices connectd but only 9 on the 2.4ghz band. 13 devices on the 5ghz band. Which seems rock solid. The phone cam I converted never loses connection.
I adjusted a lot on the router. I tried multiple channels 1,6 and 11. I tried adjusting the CTS/RTS threshold to a lower value. I tried adjusting the fragmentation length to lower. With little difference in behavior. The only thing that has helped some is setting the preamble mode to Short. That really upped the data rate to about 20-40mb/sec on the server according to performance in windows.
When they work I usually see 20-30fps.
Also, signal is pretty strong on all cameras. Wifi analyzer on my phone shows around -50db for the weakest signal. However, one of the cameras is at -35db and it drops quite often.
Any ideas how to fix this? Is this a overload issue/interference? The server is running pretty idle <20% cpu. I have a rack mount and running win 10 vm on it. I gave it 18 cores at 2.53ghz and 8 gb of ram.
If it is a wifi issue could I just lower the bitrate/quality or is the multiple cameras causing some chatter on my network? Buy another repeater? Get a better router?
Also, I should mention the error I get is 8000274c (timeout; check IP address and port) 0
Thanks!
Thanks!
