I need to replace my failed Huisun 4x camera that failed.
I still have several 10x cams going strong but I loved the wide fov I got from the 2.8mm lens on the 4x version.
Does anyone have a good recommendation for a decent priced, outdoor wide FOV PTZ? I don't think I can bring myself to by another 4x version from Huisun.
I'd like to stay under 200 bucks if possible but will go over if required. A speeddome or PTZ is fine. Just looking for something wider than I get with the 10X Huisun.
Lots of googling doesn't show too many outdoor cams with a wide FOV.
Thanks
Thanks
