I am looking for a specific type of doorbell camera, and I have not been able to find one that meets my requirements, which are:
These are the only features I need, but I have not been able to find a camera which has all four/five of them.
For example, the Ring Video Doorbell Pro supports items 1-3 but (as far as I can tell), you cannot connect to it and pull a video stream via RTSP/HTTP/etc. At $250, it's not exactly inexpensive, but the price would probably be OK if it supported #4, which it does not.
Do any of you know of any cameras that have all four of these features? If you do, I would be really glad to hear about them.
- Draws power from existing doorbell wiring / does not require any additional wiring
- Has a button which, when pressed, will ring the existing doorbell
- Connects via Wi-Fi
- Will (continuously) send video via RTSP (or HTTP or similar standard protocols)
