- Oct 20, 2015
- 6
- 1
Hi guys
I consider myself still a bit of a newbie with ip cams and wanted some feedback as to why I should use BI?
I did a bit of background research about 2 years ago and BI seemed like the go to software for ip cam roll outs. Ive set about 3 places up with cameras and BI and am generally happy with it's capabilities.
The thing is, Ive only ever used BI and have never known what it's like using an NVR, or even if I should use that instead of BI.
What I do with BI is :
Can NVR's do all that? What other features of BI am i missing out on that I should explore?
I guess why I ask is, others will quote a system with NVR and cams and they are way cheaper than the BI setup, which can cost minimum of $400 just for the pc to run BI. Whereas you can get whole kits including the cams and NVR for a couple of hundred.
http://www.lightinthebox.com/szsino...rt-mobile-phone-p2p_p4811064.html?prm=1.2.1.0
At what point to do say an NVR wont do what is required, I need BI?
- Scheduled recordings/profiles
- Recording full time with certain cams. Video when triggered + continuous.
- Recording via motion sensor. Zones and hot spot, cancel shadows, show object rectangles.
- Email alerts.
- Access via web page/phone/tablet.
