Why "show object rectangle" are not always present on playback record?
spy70
Apr 26, 2016
3
Hi,
Blueiris performs very well on my laptop samsung npv350v5c.
Only 16% cpu load!!!! with 7 hikvision 2cd2032
Only actual "issue"/question is: why the rectangle of "show object rectangle" are not always present on the recorded video?
During live, the detected objects are always with a rectangle around to show them.
So the option "show object rectangle" function well.
I even had one or two recorded video where the rectangle were present around the detected objects.
But it is not always the case. This is strange as on the live stream we could see always these rectangles.
Any idea?
Many thanks in advance for your help
If you record direct to disk, I don't think the rectangles will be in the video.
BI also has an option to "Test run video through motion detector" which you might be seeing during playback. This option can be found by right clicking a video while it is playing in the local viewer. However it won't be 100% accurate for short clips because the motion detector doesn't have a background frame fully built-up before the motion begins (so it sees less motion). This could explain why you see rectangles sometimes but not as often as you see them in the live stream.
