Why do more people not use quality White Light illuminators?
Jan 1, 2024
821
405
USA
Why Quality White Light from iluminar Stands Out
When it comes to choosing illumination solutions for your surveillance or security setup, not all white lights are created equal. iluminar's quality white light products have proven to outperform cheaper alternatives, and for good reason. Here’s why investing in superior lighting is a game-changer:
1. Unparalleled Light Quality
Cheap white lights often suffer from uneven light distribution, color distortions, or reduced efficiency. iluminar's lights deliver consistent, high-quality illumination that ensures clear visibility, accurate color rendering, and optimized performance for camera systems, especially in low-light conditions. This becomes critical when paired with high-resolution cameras, where clarity is paramount. They offer POE, POE+ and POE++ along with most of my older 12-32vdc and 24vac.
2. Dual LED Technology: IR and WL
iluminar’s use of a mix of Infrared (IR) and White Light (WL) LEDs offers unmatched versatility. The IR LEDs provide discreet illumination for scenarios requiring subtlety, such as nighttime surveillance, while the WL LEDs are ideal for overt security applications where visible lighting is necessary. This combination ensures comprehensive coverage and adaptability across various environments, catering to both covert and deterrent-focused applications. I use a mix of both lights for my security needs.
3. Remote Control for Maximum Convenience
iluminar LEDs offer remote control functionality, allowing users to fine-tune their lighting setups with ease. Whether it’s adjusting the brightness, switching between IR and WL modes, or scheduling light patterns, the remote control capability simplifies operations and reduces maintenance effort. For setups with multiple lights or hard-to-reach installations, this feature is invaluable. For me in the Snow covered times I lower the output on most of my White Leds down to 40% and most locations 80% in Spring through Summer months.
4. Built to Last
Having LEDs from 2015 and earlier still functioning effectively is a testament to iluminar’s superior build quality. Unlike cheaper alternatives that often fail prematurely due to inferior components, iluminar’s lights are designed for durability and long-term performance, making them a cost-effective investment over time. Different lights they offer from 1yr, 2yr, 3yr and 5 year warranty. 90% of mine are no longer under warranty and all working as good as they did day 1.
5. Why Settle for Less?
While cheaper white lights may seem appealing at first glance, their shortcomings in quality, reliability, and features often result in higher costs in the long run. By choosing iluminar, you’re not just buying lights; you’re investing in reliability, performance, and peace of mind.
For anyone serious about their surveillance or security systems, iluminar’s white lights, even those from 2015 or earlier, continue to demonstrate why quality matters. Don’t compromise your vision.
Picture below is of one of my smaller units, It is older 2015 so newer lights have better lenses to have better light dispersion. When I went to change out one of my Christmas bulbs I noticed the lens was dirty, Because so cold out wasn't able to clean outside so took down to clean thought I would post a picture. This is a WL436-100-POE version.
Reactions: CanCuba
