Ok folks, I'm getting conflicting reports about Dahua's Lite NVRs particularly the DHI-NVR42A04-P which I'm planning to get mainly because it's the only variant with no fan.
According to https://dahuawiki.com/Template:IVSTemplate, only the 8 and 16-ch version of the above-mentioned model DO NOT have IVS support...so is it safe to assume the 4-ch supports it?
However, on DahuaSecurity.com, it shows all the Lite Series (4/8/16) have the IVS.
http://support.dahuasecurity.com/upfile/pic/201608/201608050043432_DHI-NVR42A04-P.pdf
http://support.dahuasecurity.com/upfile/pic/201608/DHI-NVR42A08-8P.pdf
http://support.dahuasecurity.com/upfile/pic/201608/DHI-NVR42A16-16P.pdf
So which of the two do you think is telling the truth?
