White specs in 5442 lens
Krieger
Sep 23, 2022
41
33
USA
So I'm having IR bounceback issues with my 3.6mm 5442 again. Went out and cleaned the lens cover and noticed that there are what appear to be a bunch of white pain flecks inside. What is the best way to remove the lens cover? Do I need to disassemble the camera completely, or can I pop the lens cover off somehow?
Subject to correction from someone who knows more than I do about it, I believe you need to separate the camera case and pull the camera board out of the housing. Here's a picture of what you pull out (this is a 6mm 5442).
