Hello everyone
I have 2 dahua cameras (HDW5442TM-AS-LED) that I will install soon.
So I did a long search about a good VTO & VTH that will perform well, and have the ability to show my cameras feed in the VTH.
In future I will install a server to run BI or something else, but it is VTH only for now.
My final options are:
(1) Dahua : safest path for compatibility with my cameras.
VTO: VTO2211G-WP: almost good specs with good price.
VTH: VTH5341G-W: good but with an old android 8.1.
or VTO2202F-P-S2 instead of VTO2211G-WP, it is older and maybe doesn't support onvif, but has a better sensor, H.265 support and aluminum body.
(2) Hikvision :
VTO: DS-KV6113-PE1 or DS-KV8113-WME1
VTH: DS-KH9510-WTE1(B) or DS-KH9310-WTE1
they have better specs in some aspects.
also there is KD9203-FE6 but looks like it's not easy to buy for now.
My concerns:
1) COMPATIBILITY : will hikvision vth be able to view my dahua camera ?
2) onvif support since I couldn't find useful information about it in the specs.
3) This negative view of dahua : Dahua vs hikvision doorbell
Thank you !
(2) Hikvision :
My concerns:
Thank you !
