Which version of BI are you running with ALPR Database + CPAI?
Which version of BI are you running?
  • 5.9.9.10 to 5.9.9.19 (Dec 2024)
    Votes: 0 0.0%
  • 5.9.9.4 to 5.9.9.9 (Nov 2024)
    Votes: 0 0.0%
  • 5.9.8.4 to 5.9.9.3 (Oct 2024)
    Votes: 0 0.0%
  • 5.9.6.3 to 5.9.8.3 (Sept 2024)
    Votes: 0 0.0%
  • 5.9.5.3 to 5.9.6.2 (August 2024)
    Votes: 0 0.0%
  • Older than 5.9.5.3 (Pre-August 2024)
    Votes: 0 0.0%
  • Total voters
    8
PeteJ
Jan 14, 2025
192
89
California
If BI and ALPR Database is working well for you, please share which version of BI you are running.
Well = BI behavior is consistent, it handles calls out to CPAI without failures and the motion triggers all work as expected, and you are running on the recommended HW.
For this poll, I am only asking about BI. CPAI and ALPR Database are not being considered.
I've run this with a much older version of BI and the most recent. And also an older version of CPAI and the most recent.
As long as you are seeing plates detected and recording as flagged clips, then it shouldn't matter which versions you are using. The call to the ALPR Database is identical and if that is happening, then the issue is on the ALPR DB side.
I'm struggling with a number of issues, and they've changed over the last few months with each release. My main instance is .24 and aside from not processing about 2-4% of the plates, it's been super solid. This issue is said to be fixed in new versions, but each version after .24 has had it's share of problems for me, and I've been testing each release. If I can download .24 update, I'd probably just stay on it and not mess with this anymore. It's exhausting.
Reactions: Skinny1
I am running he latest version of BI and am missing 2-4% of the tags too.
