- Apr 25, 2015
- 19
- 0
Which NVR?
After struggling for weeks with these cameras ( http://www.ipcamtalk.com/showthread.php/3392-Unbranded-IP-cameras-help-please )because they don’t do what I had hoped, and upload images to FTP reliably, I think I need an NVR at this stage, because the cameras might as well be dummy cams right now for all they’re doing, they’re saving nothing at all, and the only time they work is if I’m sitting there viewing the stream.
I tried Blue Iris but it’s so resource hungry that it brought my HP MicroServer to its knees with only 2 cameras running it was maxing the CPU to 100% which resulted in Blue Iris crashing constantly.
Not only that, it insisted on resizing the feed image slightly to allow for borders which in turn reduced the clarity of the image compared to viewing the feeds in other software. I did email the developer about removing the borders but he didn’t bother responding.
So at this stage if I can’t build a really cheap and small dedicated Blue Iris box that I can tuck away in the airing cupboard then I’ll need to find the right NVR, and after making mistakes on the cameras I’d like to get this part right.
The originally seller is trying to sell me a NVR model no. BN-N6032, he reckons he usually sells them for £299 but will sell it to me “at cost” for £169, it seems a crazy price for an unbranded NVR to me.
My end setup will be 2x 1080p cams and 2x 720p cams. I want reliable motion detection as I don’t want to record video 24/7, I’d like to if possible save snapshots 24/7 but accompany this by 25fps video saved on motion detection.
Do you have any suggestions on a suitable NVR or a cheap PC to run Blue Iris?
Cheers
Cheers
