Looking to get an NVR with the option of having an alarm input. Have a new home I'm renovating and thinking about getting something I can expand upon in the future. I'm going to start out with a camera system, but would like the option to expand to door/window sensors.
Having difficulty researching online anything with an 8 port and alarm inputs, though, I may be completely confused on the inputs I'm looking at in the pictures as I'm a complete utter noob on this! I've seen the backs of some NVR's with alarm input and outputs, but also seen some units with green pin blocks (not sure what called) which looks like you can stick various wires into.
Window/door sensors would be wireless, so not sure if that can be integrated into an NVR or should be kepts as a separate system?
Is it worth getting an NVR with alarm input? Not sure how it works exactly, but my idea is having the door/window sensors set an alarm, I can have the nearest camera simultaneously send a recording text/email with screen capture or short video of the area that was triggered.
