S securipro n3wb Mar 11, 2023 3 0 ITALY Sep 2, 2024 #1 Hi ,can someone give me info about nvr compatible with my DS-2CD4A25FWD-IZ lpr camera please? Thanks a lot
trempa92 Getting comfortable Mar 26, 2020 1,179 379 Croatia,Zagreb Sep 2, 2024 #2 Compatible in the way you just want to use storage or you want to filter License plate results and search by the licenses?
S securipro n3wb Mar 11, 2023 3 0 ITALY Sep 2, 2024 #3 trempa92 said: Compatible in the way you just want to use storage or you want to filter License plate results and search by the licenses? Click to expand... I want to filter License plate results and search by the licenses Thanks for your reply
trempa92 Getting comfortable Mar 26, 2020 1,179 379 Croatia,Zagreb Sep 2, 2024 #4 DS-76xxNI-Q1(C) DS-76xxNI-Q2(C) (K9B2) not before V4.70 firmware Cheapest you can get Last edited: Sep 2, 2024
S securipro n3wb Mar 11, 2023 3 0 ITALY Sep 2, 2024 #5 trempa92 said: DS-76xxNI-Q1(C) DS-76xxNI-Q2(C) (K9B2) not before V4.70 firmware Cheapest you can get Click to expand... Thank you for enlightening me
