sebastiantombs
Lenses are sized by millimeters, typically 2.8mm, 3.6mm, 6mm, 8mm.
Sensors, the component that actually provides the picture, are sized in fractions of an inch, typically 1/3", 1/2.8", 1/1.8", 1/2". This little listing is by size with the smallest listed first, 1/3". The bigger the sensor the better the low light performance with the same resolution in megapixels.
