Sybertiger
I don't use, and have no experience with, the pass through connectors. I'm "old school" and use the dead front ones to this day. After a little learning curve, I can even do them perched on a ladder in the rain.
I added the magnified image. The stranded connectors have a prong that will pierce through the middle of the strand. The solid connectors have prongs that slide over both sides of the wire. Some RJ45 supposedly work with both stranded and solid wire. Pass-Thru connectors are a beautiful thing!
On Amazon, the Klien ad says it works for both:
- Klein exclusive Pass-Thru Connectors provide fast, reliable connector installations for data applications
- CAT6 Cable easily passes through connector to visually ensure that wires are in the correct order for consistent and secure terminations
- 50µ inch minimum gold plating on all contact surfaces
- Meets or Exceeds all PoE and PoE+ requirements for performance
- Category 6 performance per EIA/TIA B.2. FCC compliant, UL rated, RoHS compliant
- For use with Klein Tools Pass-Thru Modular Crimper VDV226-110
- 50-Pack
- 8 position, 8 contact Pass Through style data plug for solid or stranded cable
