Del Boy
Getting comfortable
Do you have a Hikvision NVR? If so, stick with Hikvision cameras. If not then I'd get the Dahua, has a mic and is better ONVIF.How does the 2342 compare to the dahua
IPC-HDW4431C-A for example? Pros cons. Or which model would be the equivalent from dahua? I only got a bunch of hikvision cams so far but it would be nice to try some dahua if it just as good or maybe even better. Thanks for your help
