I think I will keep this location but make up a special bracket and lower the camera. Maybe 15" or so. I will have to scope things out. The camera is a Hikvision DS-2CD2087G2-LU-4K in 2.8MM. It has excellent night vision.
Enough said, wife made the decision. Remember happy wife...........I have always been able to see who has come to my front door. People tend to stand a few feet from the door. However seeing packages left by the delivery people has always been a problem for the most part and that is why I decided to do something about. My wife likes the 2nd location better.![]()
A Boobie cam or a wedge cam with 2.8mm lens, at the red circle area, mounted at 5-6ft. That is your garage wall correct? It would be fairly simple to get cable through the garage wall to that location. But you would have to move the mail box or it would be in the field of view. The porch light, would probably require some shading so light doesn't affect the domes with reflections. Paint cams same color as your stucco, and 99% of folks would never see it.
Boobie cam to view pointed down for packages and the other cam for face's at the door.
The other option is the yellow location on the left of the door, choice of either cam.
I have both cams available, if theres' anything you like for me to try with those cams, just give the word.
Review-dahua-ipc-hdbw4231f-e2-m-dual-starlight-cam Note: there is a newer updated version of this cam on the immediate horizon as soon as a couple of quicks are ironed out.
Dahua-Review of IPC-HDBW4231E-AS Mini Dome Starlight Cam | IP Cam Talk
Well then there's your answer, man!My wife likes the 2nd location better.![]()
With your new location, curious what it would look like if you span it 90degree to "corridor" mode, with the top edge of the image at the top of the door like it is now.
Well just spinning it and tilting your head sideways you'd expect to see more given the horizontal FOV is wider than the vertical FOV.
So with the horizontal now aligned to the top of the door, you should see the whole of the second post at the "bottom" of the image.
Cam spec says it has a rotate image feature (corridor by another name), tho it's going to look odd with the bullet mounted sideways, sure.
That is the problem. The aspect ratio is out of whack on IVMS-4200 in the corridor mode.I'd think there'd be a setting in IVMN-4200 for that camera that could cure that relating to aspect ratio or such.
I understand, but I'd think there would be a setting to correct that in IVMS. Just a guess as I don't have IVMS.That is the problem. The aspect ratio is out of whack on IVMS-4200 in the corridor mode.
