- Jan 16, 2015
- 526
- 27
i made a drawing so it could be easier to solve lol.which lens should i get for that distance.3.6 or 6mm? cam will be facing straight up into the street.post is about 8 feet high but i can make it higher.i'm leaning towards the dahua bullet for this project but i also have the dome on my mind.red is where i'm going to install the cam but i could change to a different post if i wanted to.cars from family members park and go pretty often.i will be adding a pir sensor to the left of the cam(red dot) or underneath red dot.what do u guys think?
http://www.aliexpress.com/item/2016...58.html?spm=2114.13010208.99999999.273.apqMlx
http://www.aliexpress.com/item/Dahu...51.html?spm=2114.13010208.99999999.261.apqMlx
